gtlaw
JcRoush hater
i'm not so much worried about the hood but with my functional air brake side scoops and quarter window scoops I fear I might rip the entire side off my car off.
The stock latch and rubber bumps stops are in tact, but where adjusted for better hood and front bumper cover alignment. The rubber bumps are raised to be a little tighter now that I have the latches. The dealer will do nothing to fix the issue, whatever they do it will have no effect.Do those replace the "factory" latch system? Or are they a "supliment"
Also have issues with "hood shake" over 70 mph,have tried adjusting rubber stops with no success.Probably have dealer address at first service.
As far as I'm concerned,this is completely unacceptable,never owned a vehicle where the hood shakes,even when I drove various POS's when I was a kid.
P
After posting this I found 3 out of the 4 bolts holding the hood hinges weren't torqued down. I tightened them and was doing 80ish and it seemed to help as it was almost steady, but a little movement, which was good for me. When I started this thread I was over 100 one day when it became apparent the shaking was something I didn't like. Guess I better get up to more speed and see if it has gotten any better.Mine does the same, stealership said it was fine. It bounces up and down a lot when doing 90.
Edit: After reading this, I just adjusted to three lines on the hood bumps. Hopefully that fixes it. Dealership should have adjusted this when I told them about it on my last visit. Pisses me off
I noticed when I screwed the rubber bump stops up the hood did appear slightly more stable at hwy speeds, but pass a truck and it was bobbling again. Also moving the stop up pushed the hood ends up and created beg gaps at the bumper cover to hood ends near the headlights.Mine does the same, stealership said it was fine. It bounces up and down a lot when doing 90.
