Juben
- Jan 29, 2015
- Chattanooga, TN
- Justin
- 2015 EcoBoost Mustang (AT) w/PP
Try a different brand of gas. Are you getting it from the same station? BP is usually decent in terms of quality, but if the station you're using is old with crappy fuel tanks or doesn't see a lot of volume then that could be the problem too. Try running it almost dry and using a different brand of fuel, like Chevron, from a gas station that sees a lot of traffic.I've run nothing but BP up to this point
5.5 max on 91 @ 11.2 AFR @ 19.72 PSI
9.5 max on 93 @ 11 AFR @ 20 PSI
This is the thing, all figures seem to be fairly safe and standard yet it's still pulling the OAR. Could the knock sensor be picking up on other noises?
BTW, all logs are posted in the OP.
And yes, the knock sensor can pick up other noise. It's called false knock and would usually come from something being loose and rattling around, like the exhaust. Make sure everything has proper clearance and is tightened down sufficiently. Check both sides of the engine, the exhaust, etc.
