11.998 street tires manual n/a
iketh
Orlando, FL
Keith
Great runs, I was the guy in the white hat w/ the tripod filming next to the tree at OSW. Loved watching your car rip
Just installed Stainless Power LT's with Corsa Extreme this week, what part of Orlando are you at?
I'm in Kissimmee.
iketh
Orlando, FL
Keith
ya I researched for a while and they were the best choice overall a year ago, probably still are today... I went square and they rub the front caliper by about 1mm when new
with tires, mounted, and balanced, weight of my factory 18" is 57lbs, these are 46lbs, 44lb savings overall... it's a little less than 44lb effective because more of the 46lbs is on the perimeter because 19" compared to 18"
Chach805
Port hueneme, ca
2015 C/O w/ PP
Iketh: awesome runs man, very impressive! Hey would you be able to give a brief run down on how you luanch ur car off the line?
ZanarkO
Richmond
2006 Evo IX, 2000 C5, 2006 Eclipse GT, 2003 Evo 8
Is that a base car or PP noticed you didnt need to shift into 5th gear
Silver50Pony
Westchester NY
2015 5.0 PP Ingot Silver
Even with PP you shouldn't need to shift into 5th ever unless you have stock rev limiter maybe . I never had to hit 5th. He's running 3.55 gears if I remember right not 3.73 that the PP has.
iketh
Orlando, FL
Keith
Watch the throttle gauge in the video to see how I'm working the throttle. When I'm part throttle, I'm also part clutch (feathering throttle and clutch). Clutch is 100% engaged when 100% throttle. DR/slicks will be a little different.
iketh
Orlando, FL
Keith
Yes it's the base with 3.55 rear
ZanarkO
Richmond
Did you change it out yourself or did you order it from ford with the 3.55. I have a base as well and was thinking of just ordering the $800 assembly. Not sure if itll be worth the price but your gearing seems perfect for an NA car.
iketh
Orlando, FL
Keith
yea it really is perfect, and it'll still be perfect with cobra jet revving to 8k trapping 126ish
this is how it was on the lot, 3.55 rear was the only added option
TrackpackGT
NC
15 Mustang GT PP
Finally got mine to the track. I have 3.73's SW LT's with cats, MGW shifter, and PBD tune. My best MPH was 113.5 and a 12.6X on a 2.1. Gotta work on that 60ft, but the track and Conti DW's weren't having that. I guess those wheels and driveshaft really make a big difference. Any suspension goodies?
