aFe POWER
- Jun 2, 2015
- Corona, CA
- Website
- www.afepower.com
- 2015 Ford Mustang 5.0L
aFe POWER has long been known for performance upgrades, and our sister company aFe CONTROL handles the suspension side. For the S550 Mustang we’ve been hard at work on a variety of suspension upgrades including coilovers, spring kits, and we are really happy to introduce the aFe CONTROL Sway Bar Set.
This fully adjustable front and rear sway bar set is perfect for the street and at home at the track, where extensive testing has confirmed the bars abilities to reduce body roll, keep flatter turns, and with the adjustability in both front and rear sway bars make adjustments to under/oversteer.
Quick Key Data Points:
• CNC Bent Tubular Alloy Steel, adds increased strength over the OEM bars.
• 35mm 2 way adjustable in the front, and 32mm 3 way adjustable in the rear.
• CNC Machined and TIG welded ends offer superior strength.
• Polyurethane bushings with CNC machined 6061-T6 aluminum brackets for reduced deflection.
• 2 stage Tangerine Orange powdercoated finish increases long lasting durable finish.
• Direct bolt-on installation, fits I4, V6, and V8 S550 Mustang models with no modifications.
• Engineered and Crafted at our facility in Corona, CA.
In the pursuit of balance, handling and reduced body roll, we also kept in mind that not all drivers are equal. The front bar features 2-way adjustability, and 3-way for the rear sway bar. We designed our bars of lightweight tubular steel, with polyurethane bushings and billet aluminum CNC machined brackets to further assist in reducing deflection.
aFe CONTROL Sway Bar ends come CNC machined, along with being TIG welded to produce a strong consistent flange. Our ends offer improved strength over other sway bars that have the “squished” ends, which can lead to potential failure under hard loads. To maintain durability for many years, we incorporated a Two Stage Tangerine Orange Powdercoating as part of the attention to detail. If you want your S550 Mustang to hug corners, you just found the solution.
Visit us at http://afepower.com/shop/application_searchnew.php?searchtype=combo&keyword=mustang&brandID=142 to pre-order or PM me for more questions and pricing.
We didn't leave the Ecoboost and V6 guys out, we have a package for you as well. Check out our stage one package on our blog as well.
http://afepower.com/blog/new-product-release-afe-control-series-stage-1-suspension-package-for-2015-ford-mustang-i4v6/
