BMR Tech Tip: Check those axle-to-spindle retaining nuts!
Status
Not open for further replies.
Angry50
Jacksonville, FL
Fred
2017 Shelby GT350
i havent experienced any symptoms but this makes me want to check
TNcoupe
Decatur, TN
Josh
2015 GT PP
Did the right rear on mine yesterday. It was significantly tighter than the LR.
bandit67
Mustang Addict
Lake Hartwell, SC
2015 GT, 2007 SPJ 302, 2019 Ranger
So I had a chance to pull the driver side rear wheel this morning on my GT, since that seems to be the most problematic side. This particular car only has just under 1900 miles on it, and the spindle nut did not budge with my torque wrench set at 150 ftlbs.
On my car, the stock nut has cutouts for a cotter pin. I added some red locktite at all of the cutout points, though I have no idea if that will really do anything, since locktite is designed to be spread into the threads when installing the nut onto the bolt. I did not want to loosen the stock nut to properly install the locktite, because that essentially would have rendered the existing nut unusable, as they are a one-time use piece. I still have to check the passenger side nut, but will do that when I can pull the car out of the garage.
I picked up 2 new nuts today to have on hand, just in case. Part number CCPZ-3B477-F, which do not have cotter pin cutouts, and appear to be Ford's silver grade 10.9 one-time use hardware.
SidewaysMike
Somehwhere in the Med
2016 GT PP
That's correct, CCPZ-3B477-F replaces nut CV6Z-3B477-A.
So the new one doesn't have the cut outs.
FWIW this is used on a lot of Ford and Lincoln hubs
TwinReverb
OKC
Alan
2016 Mustang GT PP
I'd like to add that you may want to also check your wheel bearing while there.
[ame]
tsloms
Wisconsin
2016 Mustang GT Magnetic PP
While upgrading my suspension I noticed as well that my driver's rear wheel bearing was toast after 500 miles!! :eyebulge::shrug:
Gnfanatic
Long Island
2017 Ruby Red GT PP, 1986 Buick GN
What is up with these POS wheel bearings? 600 miles?? Un-acceptable!!
HISSMAN
Large Member
West Virginia
2016 Oxford White GT/PP Premium
Damn...Must check my wheel bearings tonight..
cechk01
RVA
2016 DIB GTPP
I checked my wheel bearings all fine, I replaced the nut on the creaking wheel with CCPZ-3B477-F. The new one had some green stuff on the inside on the threads, maybe thread locker or anti seize?
imgur.com/gallery/cqu4N
I don't think the old one had any
TNcoupe
Decatur, TN
Josh
2015 GT PP
The bad wheel bearings could be a victim of the hub nut coming loose. Running a wheel bearing with too little preload can be as bad as running one with too much pre load.
BMR Tech
BMR Tech
Tampa, FL
www.bmrsuspension.com
Dion
^ This.
I have had this theory for a while now, that I truly believe that the bearings failing so often could be based on the clamping load of the nuts decreasing.
This is why I basically ignore any TQ specs or procedures....and go straight to 150ftlbs + 1/8 turn with Red Loctite.
BMR Tech
BMR Tech
Tampa, FL
Dion
I had a friend with a car that had 1900 miles on it. We were swapping his wheels out a while back and for shits and giggles, I decided to check his TQ on his OEM never touched retaining nuts.
The passenger side came out to about 115ftlbs and the driver side, took half a turn to get to 100ftlbs. lol
TNcoupe
Decatur, TN
Josh
2015 GT PP
^ This.
I know because of experience....you know the indestructable 9" Ford rear end??? Well I destroyed one because of not enough preload on the pinion bearings, and running 37" Super Swampers. Pinion was thrusting under load and ate up a set of Richmond 4.56 gears.
tsloms
Wisconsin
Remember that with our unitized bearings in a sealed housing the nut doesn't affect preload on the bearings. It only sandwiches the hub and tightens on the hub.
Regardless I'll need to double check and loctite my nuts to ensure they are tight!
Status
