chain
I am about to buy a 19x10 set of wheels for a square set up for the track (road course) and auto-x. I will be using the PP wheels and tires for normal street use. Anyways I see a couple options and not exactly sure which way to go. I plan to go with the Michelin Pilot Super Sport's. Any help on which size to go with and why would be much appreciated. Thanks
285/35ZR19(99Y) - 28lbs a tire, slightly smaller diameter than the rears that come on the PP (26.9" vs 27.7"), little bit wider tread
275/40ZR19/XL105(Y) - 29lbs a tire, same diameter as the rear PP (27.7"), little less width on the tread
285/40ZR19/XL(107Y) - 31lbs a tire, slightly larger than the rear PP (28" vs 27.7")
