- Dec 18, 2014
- Atlanta, GA
- 2015 6spd GT
2015-2016 Mustang Carbon Fiber Upper Grille
You can do all kind of upgrades to the front grill on your Mustang but why not do it in Carbon Fiber.
If you need Carbon Fiber components to your 2015-2016 V6, EcoBoost or GT Mustang, then look no further then Anderson Composites. Their Type-GT Upper Grille (P/N: AC-FG15FDMU-GT) will truly change the appearance of your S550 front-end with a beautifully designed Carbon Fiber replacement!
This Type-GT Upper Grille from Anderson Composites is a direct replacement for your factory grille. It will easily take the place of the existing upper grille in your 2015-2016 V6, EcoBoost or GT Mustang and use the original hardware. The high-quality wet carbon fiber construction is not only lightweight, but it is also exceptionally strong and built to last. Featuring a high-gloss clear coat finish that will show off the weave of the meticulous hand laid carbon fiber, this Type-GT Upper Grille with the included diamond patterned mesh screen will significantly stand out on this modern day muscle car.
Features and Benefits:
- Direct Replacement for OE Upper Grille
- Reuses Your Existing Grille Hardware
- High-Quality Wet Carbon Fiber Construction
- Lightweight and Strong 1-Piece Design
- Durable High-Gloss Clear Coat Finish
- Includes Diamond Patterned Mesh Screen
- Fits ALL V6, EcoBoost and GT Mustangs
Please Note: Proper installation of this Upper Grille WILL require you to remove your front bumper.
*Will NOT fit GT350, GT350R, Roush and Saleen Front Bumpers.
Anderson Composites specializes in fiberglass and carbon fiber components for late-model Mustangs. They manufacture each and every one of their products with the upmost attention to detail and only use top-grade materials for a quality product you can trust. Their extensive manufacturing experience allows them to construct everything from hoods, trunk lids, front and rear spoilers, side skirts/splitters and much more. Anderson Composites’ precision and attention to detail used to make their products is a science of its own and their craftsmanship is simply unmatched.
Order here: 2015-2016 Mustang Carbon Fiber Upper Grille
