wildcatgoal
@sirboom_photography
No need to go lower. My car is 3/4" lower, too, seems to like that height.
Goes right above the shock body.Thanks for the clarification. So the split nylon washer goes on the top side of the bump stop?
Ummm, I'll think about it? ;)If you want an even more dramatic improvement, send me your Recaro seats and I'll send you my Premium non-Recaro seats and you can have seats I farted in!
#itried
Kidding, glad you like the setup man. Get yourself to an HPDE and have some fun (safely).
I am with you on this, i think im going to try and get some tender springs. Something like these:https://vorshlag-store.com/collecti...g-60mm-tender-spring-each?variant=15148627399One thing I was surprised to see is that the front coilover ride height adjustment is just a couple threads from the bottom, and the car isn't THAT low. Another thing that concerned me was that with the threaded collar adjusted that low, in an event that the strut ever becomes fully unloaded, the spring and upper strut thrust bearing will be completely unloaded and free to move about. That doesn't seem right to me. Anyways.......`
Steeda is checking into the proper tender springs for people with concerns.I am with you on this, i think im going to try and get some tender springs. Something like these:https://vorshlag-store.com/collecti...g-60mm-tender-spring-each?variant=15148627399
It just seems that with the adjustment that theses things have they would include them so when lifting the car your spring does not set wrong when putting it back on thr ground or the thrust bearing becomes unseated.
Awesome. Keep us posted.Steeda is checking into the proper tender springs for people with concerns.
On another note, we do not run tender springs on our S550 SCCA T1 Racer.
Steeda Tech
You should be able to assemble the front with out a spring compressor.Quick install question- do you need to use a spring compressor to assemble the fronts?
Continues to set the bar high!Introduction price 1299.00 Regular price 1699.00
Ready to step up to an adjustable suspension setup on your S550 Mustang? Buy the one with the most research and engineering, and a National SCCA competition proven winner setup. Designed and engineered in the U.S.A! This kit will combine our Pro-Action Front Coilovers and our Adjustable Rear Ride Height Kit!
Steeda S550 Mustang includes custom designed Pro-Action adjustable front struts which feature rebound adjustment. Threaded collars and spring perches offer easy ride height adjustment from stock to 2" lowering.
The Steeda S550 Mustang Front Coilovers also includes our Steeda custom designed adjustable bumpstops! Allowing you to adjust your suspension travel for the ultimate in performance for any application.
The front coilover system also utilizes our Steeda S550 Mustang Camber Plates that provide - 3 degrees of camber adjustment.
Steeda's S550 Mustang Adjustable Rear Ride Height Kit will give you the ability to lower the rear of your S550 Mustang from 3/4" to 1-1/2", this kit allows you to dial in the ride height to your liking. The rear Ride Height Adjusters are made from billet 6061 aluminum in house and Hardcoat anodized for the ultimate in strength and protection. These simply install above the rear springs and come with an included wrench to allow you to adjust your height with ease. The Steeda kit is also designed with a locking set screw to hold your adjustment in place. Add in Steeda's Pro-Action Shocks for even more rear control and reduced wheel hop and body oscillation and you have a winning combination!
Product Benefits
- Designed, engineered, and tested on winning S550 Mustangs both on the drag strip and road course
- Ideal for any street or track Mustang
- Custom designed Pro-Action adjustable front struts with rebound adjustment
- Tig-welded and CNC machined pieces for exact tolerances
- Highest quality hardware
- Increased front grip, turn-in response, and cornering performance
- Specifically designed for the S550 chassis and front suspension system
- Ability to lower ride height 2" in front
- Ability to lower ride height from 3/4" to 1-1/2" in the rear
- Less damper friction, less side-loading on the shafts, lower internal pressures
- Bolt-In installation - No permanent modifications required
- National SCCA Majors competition proven winner setup
- Made in the USA
- Lifetime warranty
850- 1000 lb/in is correct for the 555-8171The rear adjustable spring set (555 8171) are listed on the Steeda website as 1000-1100 lb/in spring rate, however the spring guide I received (linked below) from a Steeda rep during an online chat lists them at 850-1000 lb/in spring rate progressive.
When I questioned the rep he said the chart is correct, the website is wrong, and that the springs are dual rate. This makes sense because you can see the top coil spacing is tighter meaning it will kill out quickly and the rest are evenly spaced so it's linear from there on.
I would like to get a final, 100% confirmed spring rate for these rear springs, please.
https://www.dropbox.com/s/cmn4sqco1xbtadf/Steeda S550 Spring Guide.pdf?dl=0
