Steeda S550 Pro-Action Front Coilovers With Adjustable Rear Ride Height Kit
SteedaTech
Pompano Beach, FL
2016 Mustang Q750
Introduction price 1299.00 Regular price 1699.00
Ready to step up to an adjustable suspension setup on your S550 Mustang? Buy the one with the most research and engineering, and a National SCCA competition proven winner setup. Designed and engineered in the U.S.A! This kit will combine our Pro-Action Front Coilovers and our Adjustable Rear Ride Height Kit!
Steeda S550 Mustang includes custom designed Pro-Action adjustable front struts which feature rebound adjustment. Threaded collars and spring perches offer easy ride height adjustment from stock to 2" lowering.
The Steeda S550 Mustang Front Coilovers also includes our Steeda custom designed adjustable bumpstops! Allowing you to adjust your suspension travel for the ultimate in performance for any application.
The front coilover system also utilizes our Steeda S550 Mustang Camber Plates that provide - 3 degrees of camber adjustment.
Steeda's S550 Mustang Adjustable Rear Ride Height Kit will give you the ability to lower the rear of your S550 Mustang from 3/4" to 1-1/2", this kit allows you to dial in the ride height to your liking. The rear Ride Height Adjusters are made from billet 6061 aluminum in house and Hardcoat anodized for the ultimate in strength and protection. These simply install above the rear springs and come with an included wrench to allow you to adjust your height with ease. The Steeda kit is also designed with a locking set screw to hold your adjustment in place. Add in Steeda's Pro-Action Shocks for even more rear control and reduced wheel hop and body oscillation and you have a winning combination!
Product Benefits
  • Designed, engineered, and tested on winning S550 Mustangs both on the drag strip and road course
  • Ideal for any street or track Mustang
  • Custom designed Pro-Action adjustable front struts with rebound adjustment
  • Tig-welded and CNC machined pieces for exact tolerances
  • Highest quality hardware
  • Increased front grip, turn-in response, and cornering performance
  • Specifically designed for the S550 chassis and front suspension system
  • Ability to lower ride height 2" in front
  • Ability to lower ride height from 3/4" to 1-1/2" in the rear
  • Less damper friction, less side-loading on the shafts, lower internal pressures
  • Bolt-In installation - No permanent modifications required
  • National SCCA Majors competition proven winner setup
  • Made in the USA
  • Lifetime warranty
Performance nut
TX
2018 Mustang GT A10
I almost regret getting the Pro adjustable shocks and struts now... almost. :)
Few questions for you:
  • What is different between the front pro adjustable shock with a Steeda spring and the front coil over (aside from height adjustability)?
  • The front adjusts stock to -2" whereas the back adjusts -3/4 to -1 1/2". I take it that it wasn't easy to get the rear to adjust from stock to -1 1/2". Do you see a way to get the rear up to stock height without compromising the ride or function of these pieces? Reason I ask is to get the full benefit of the front coilover range in the event I wish to stay stock height in areas not friendly to cars that ride low.
tj@steeda
Timothy
Yarr
Columbus, OH
2016 Mustang GT Premium, 401A, Oxford White
What front spring rate do you recommend with these for Autocross/HPDE with a GT? Been waiting for this kit to come out, definitely getting it
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
Just so I'm more educated, what rear springs does this come with (rates)?
slink914
Tampa
2015 Eco
The web site shows 1000-1100 , for the rear kit, I assume they're the same in the full kit. IF they will offer this with lighter rear springs I'll order tomorrow.
On that note TJ can you send me the forum discount code please.
SteedaTech
SteedaTech
Pompano Beach, FL
2016 Mustang Q750
You are correct. With a 250lbs/in front and the 1000 to 1100lbs/in rear rate you will be surprised on how good the ride quality is.
What are your objectives in the ride and handling dept?
All the best,
Steeda Tech
BmacIL
Enginerd
Naperville, IL
Ok thanks. I'm at 240 front and 980 rear and can confirm it rides quite well with good dampers (I have the fixed valve pro actions).
slink914
Tampa
2015 Eco
You are correct. With a 250lbs/in front and the 1000 to 1100lbs/in rear rate you will e surprised on how good the ride quality is.
All the best,
Steeda Tech
Well , I have an eco-premium, How would those rates be with the eco. The Car is a DD with a couple of track days.
BmacIL
Enginerd
Naperville, IL
Probably around 200 or 225 front would be good for the Eco.
THE_AHJ
AuthorityHvngJurisdiction
562 ~ 714
Alberto
Metrolink
What about a stock GT PP looking for a 1" drop. It's my DD and I don't track it. I'm looking at doing a 19x9.5 square setup in the future.
slink914
Tampa
2015 Eco
yes I would think 225 would be tops , not for me so much but the wife has a pretty good buttdyno .
DAVECS1
Peoria IL
2017 PP GT Grabber Blue
Well I was thinking Pedders, but now I am thinking Steeda. I LIKE THE INCLUDED camber plates
Gurjit
B.C. Canada
2016 GT Premium performance pack
I want.
