Stuntman
The lack of compression vs rebound Jacks the car down after hitting a bump, (pulls the sprung mass down to the ground), which makes for a stiff ride. All 4 cars I had Koni yellows on did this as well as most rebound-adjustable coilovers that don't have sufficient compression.
Since Koni yellows are rebound adjustable, stiffening it will make that feeling far worse. Likewise if you have a double adjustable coilovers with a wide range, you can simulate this or try s compression-biased damping curve.
