Which is natural, but when the engine bay is THAT hot.... it's easier to contain the heat in the turbo, wrap the charge pipes and exhaust so it keeps engine bay as a whole cooler whilst driving.Which I already do after some spirited driving during the hot summer days, LOL!
That same reasoning works for the components you are trying to protect with a turbo blanket. If you assume the layout of the engine bay--including the stock heat shield--was designed to ensure turbo heat doesn't adversely affect under-the-hood components, then why do you need a turbo blanket?It's a water / oil cooled turbo aint it? it'll be fine lol as long as after extreme driving I don't shut the car off and I pop hood and let the coolant and oil do it's job it's fine.
I would guess the good old Ecoboost Mustang has a heat shield because of $ compared to $$$...That same reasoning works for the components you are trying to protect with a turbo blanket. If you assume the layout of the engine bay--including the stock heat shield--was designed to ensure turbo heat doesn't adversely affect under-the-hood components, then why do you need a turbo blanket?
If you are increasing the boost significantly beyond stock then it might behoove you to take some under-the-hood measurements to determine if a blanket is warranted, otherwise I don't see the benefit of a turbo blanket. This is especially true if you don't have data on heat limits for the turbo and exhaust system components, data which presumably the factory DOES have, and which presumably was factored in to the decision whether or not to equip the car with a turbo blanket rather than a simple heat shield.
Yeah, there're a lot of mods installed based on guesses...I would guess the good old Ecoboost Mustang has a heat shield because of $ compared to $$$...
I also agree, this is simply a solution looking for a problem scenario similar to the catch can debate. It all looks its great on the surface but the more you consider the less you actually know what your doing and why? There is no evidence that this application needs a turbo blanket in appose to the existing shield also considering the amount of space in between the engine bay makes me believe there is even less reason, there are too many variables that have not been answered or tested.^ I would agree
:headbonk:Yeah, there're a lot of mods installed based on guesses...
My pipes are stainless so that's fine.Wrapping the pipes creates more heat IN the pipes, this leads to faster turbo spooling. Its also a godsend on track days when you need work on the car and not burn the crap out of yourself. For non stainless piping, wrapping the piping can lead to premature rusting of the piping.
There's no question that turbo blankets can increase turbo performance, but there ARE tradeoffs. A wrapped turbo is more difficult to visually inspect, and retaining the heat will affect durability. Same goes for stainless piping.Wrapping the pipes creates more heat IN the pipes, this leads to faster turbo spooling. Its also a godsend on track days when you need work on the car and not burn the crap out of yourself. For non stainless piping, wrapping the piping can lead to premature rusting of the piping.
Ahhh! Asking the question is the first step to getting the answer. What is the design thermal limit of the turbo? What is the heat rejection capability of the installed cooling system? What temp will the turbo attain with/without a blanket?I fully agree with knowing the pro's and cons, hense the reason for the topic.
there's some that state that trapping the heat ont he turbo will cause adverse effects, however my thinking is as long as you dont go and slam the car around and shut the engine off straight away the internal cooling mechanisms will cool it down to a suitable temp?
