CJ Pony Parts
- Dec 21, 2015
- Harrisburg, PA
- Website
- www.cjponyparts.com
- A large variety of Mustangs across all generations
We have another set of these available. FYI, this set is in far better condition than the last set.
Just like any retail business, from time to time we get returns. A lot of times there is little to nothing wrong with the actual product and more often than not a customer just changes their mind. Luckily we have our eBay Store which will allow us to pass on great savings to people that aren't worried about a possible scratch or dent, maybe a missing washer, nut or even instructions.
If a used, returned or discontinued item is posted on our eBay Store, we try to take as many photos as possible and explain what (if anything) is missing and/or damaged. Below is a perfect example of this.
Set of 4 - 2005-17 Mustang V6 Ecoboost GT VMB9 Velgen Wheels Satin Bronze 20"
Item condition: New other (see details)
"These wheels were sold and returned because of chips on the edge of two of the rear wheels. See pictures."
Set of Four Velgen 20" x 9" and 20" x 10.5" Satin Bronze VMB9 Wheels for all 2005, 2006, 2007, 2008, 2009, 2010, 2011, 2012, 2013, 2014, 2015, 2016 and 2017 V6, EcoBoost and GT Mustangs.
The Mustang wheel market isn't very big outside the world of replica wheels unless you're looking to spend a few thousand for a custom set of wheels. Velgen Wheels is filling that void with their VMB9 style wheels.
This set of four 20" x 9" and 20" x 10.5" VMB9 wheels feature 9 individual spokes. The spoke design is similar to other very popular race-inspired aluminum wheels. The spokes are also skinnier and reminiscent of competition wheels. A slight lip sits just behind the spokes on the barrel. The aluminum monoblock wheels are cast, then sent through three CNC machining stages for a perfect finished product. These wheels are finished with a satin bronze powder coat to create a stealthy and unique appearance on your Mustang. A stylish center cap features Velgen's name for each wheel.
The 20" diameter wheel provides a large amount of clearance for big brake kits and has no problem fitting around the factory 15" Performance Pack Brakes found on the new 2015-2017 GT Mustangs. These Velgen wheels require a metal hubcentric ring for installation.
These Velgen Wheels also require small diameter lug nuts. Larger OEM style lug nuts will NOT work.
*Sold as a staggered 20x9 and 20x10.5 Set of Four Wheels.
Tech Tip: This set of wheels are NOT intended for use with the 2015-2017 Shelby GT350 and GT350R.
Like all Velgen wheels, the 20" x 9" and 20" x 10.5" VMB9 wheels are low pressure cast wheels. Low pressure casting uses positive pressure to move the molten aluminum into the mold quicker. This helps improve mechanical properties and achieve a finished product that is denser than a gravity cast wheel. Low pressure casting is the most common process approved for aluminum wheels sold to the OEM market and it offers a good value for the aftermarket as well. Although low pressure casting has a slightly higher production cost over gravity casting, it allows for a higher quality product. After the VMB9 wheel is manufactured, it is put through a series of tests including radial testing, impact testing and fatigue testing.
This set of wheels retails for $1800.00. Don't miss this deal at a fraction of the cost!
THIS IS A FINAL SALE THERE WILL BE NO RETURNS OR REFUNDS ON THIS ITEM
