SVT-DADDY
World's heaviest S550
When I was car shopping I had a real tough time deciding between getting a PP vert or buying a premium that had foundry wheels. I like the foundry wheels better than even the aftermarket wheels for this car so went that direction . I am not ashamed to admit that I have had PP envy ever since. I have finicky tastes on things, so this really turned into a bit of an oddball build. Looking for a mild upgrade here to preserve ride quality.
Here is what I am doing and why, looking for some feedback. Questions below:
Front springs-BMR min drop. I don’t like a car that sits too low and this car has to go down a slightly rutted gravel road a couple times per year. These are on the car but without replacing the struts the car is too bouncy.
Rear Springs- PP take offs from a 2015 coupe, got these for next to nothing. I wanted a stiffer spring but didn’t want to lower the rear of the car because I like a little rake and I actually use the rear seats.
Shocks&Struts- 2017 PP vert pieces. I waivered heavily between this choice and the Steeda Adjustable. I wanted something a little more controlled without sacrificing ride quality. The value on these is tough to beat, I just hope they are “enough” for me!
Sways- 2017 PP vert pieces for the same reason as above.
Chassis- Steeda 4 point K brace, and Steeda IRS bushing support system. These are really more in prep for a future FI upgrade. Can't have enough stiffness in a vert.
Questions:
-With such a small drop(3/4”) do I need camber bolts?
-Is it worth it to get the IRS alignment bushings or does the support kit handle that?
-Worth it to get better bushings for the bars on such a mild set up?
-I’ll eventually get the upper shock mounts, but I want to change them alone so I can see what everyone is raving about.
-Anything else?
Thanks!
Questions:
-Anything else?
Thanks!
