- Dec 18, 2014
- Atlanta, GA
- 2015 6spd GT
2015-2016 Mustang Carbon Fiber Radiator Cover
The underhood of your new Mustang is a great way to start with dress-up items.
If you are in the market to add high-quality Carbon Fiber components to your 2015-2016 V6, EcoBoost or GT Mustang, then look no further then Anderson Composites. Their Radiator Support Cover (P/N: AC-CP15FDMU) will truly change the appearance of your S550 engine bay with a beautifully designed Carbon Fiber replacement!
This Radiator Support Cover from Anderson Composites is a direct replacement for your factory radiator support cover. It will easily take the place of the existing radiator support cover in your 2015-2016 V6, EcoBoost or GT Mustang and reuse the original hardware. The high-quality wet carbon fiber construction is not only lightweight, but it is also exceptionally strong and built to last. Featuring a high-gloss clear coat finish that will show off the weave of the meticulous hand laid carbon fiber, this Radiator Support Cover retains all factory locations for the hood latch and prop rod and will significantly stand out on your 2015-2016 Mustang.
Features and Benefits:
- Direct Replacement for OE Radiator Support Cover
- Reuses Your Existing Radiator Support Cover Hardware
- High-Quality Wet Carbon Fiber Construction
- Lightweight and Strong 1-Piece Design
- Durable High-Gloss Clear Coat Finish
- Retains ALL Factory Locations for the Hood Latch and Prop Rod
- Fits ALL V6, EcoBoost and GT Mustangs.
*Will NOT fit on the Shelby GT350 and GT350R models.
Anderson Composites specializes in fiberglass and carbon fiber components for late-model Mustangs. They manufacture each and every one of their products with the upmost attention to detail and only use top-grade materials for a quality product you can trust. Their extensive manufacturing experience allows them to construct everything from hoods, trunk lids, front and rear spoilers, side skirts/splitters and much more. Anderson Composites’ precision and attention to detail used to make their products is a science of its own and their craftsmanship is simply unmatched.
Order here: 2015-2016 Mustang Carbon Fiber Radiator Cover
