Boomba Racing
- Oct 30, 2014
- Wood Dale, IL
- Website
- www.boombaracing.com
- 2015 Mustang Ecoboost TY 6MT w/ PP
Any previous customers of our Catch Can, enter the code "CCDRAIN" at the last screen of checkout to save 15% off this piece!
To make draining your Boomba Racing Catch Can even easier!
Introducing the Boomba Racing Quick Drain Valve. This piece is meant to replace the 3/16” Allen head NPT plug located at the bottom of your can. This new elbow threads in the preexisting 1/8” threaded hole in the bottom of your catch can and makes emptying the can a breeze. To drain via this valve, all you have to do is open the 3mm Allen screw by loosening it, let your contents drain, tighten it back up, and be on your way!
CNC machined from corrosion resistant stainless steel in-house in Wood Dale, Illinois.
Uses ¼” hose for fitting.
Link: http://www.boombaracing.com/catch-can-quick-drain-valve/
