- Oct 7, 2014
- California
- Website
- www.modularmotorsportsracing.com
- Worlds Fastest & Only 5 second Coyote
2015-2016 2.3 ECOBOOST MMR/ Manley Forged Pistons, Manley 4340 Forged Billet I beam Rods by Manley and Total Seal rings Planning Higher boost, turbo upgrade or a shot of nitrous, these are a MUST. Built for MMR by Manley Products. Designed to handle up to 1000 HP. These are a direct fit. Includes ARP 2000 Rod Bolts and Moly Lube.
$1299.99
Rods:
*I Beam design
*4340 Billet Material
*ARP 2000 Rod Bolts
*Compatible with factory style bearings and crankshaft (must verify clearances)
*Requires no modifications to work, just balance, and machine for proper clearances
Pistons:
*2618 Forged Material
*Thicker crown and skirt for increased power capacity
*Improved ring land design for better durability
*Production compression ratio standard (can custom order in different compression ratios)
*Crown coated with ceramic heat barrier to improve piston durability
*Skirt coated with a Teflon based anti friction material to improve skirt wear
Package Includes: Billet Rods, Coated Pistons, Piston Pins, and Total seal brand Rings
$1299.99
Rods:
*I Beam design
*ARP 2000 Rod Bolts
Pistons:
