cyandhappiness
- Mar 1, 2015
- United States
- 15 GT Premium PP
Seems like mine is hard code to 4 as well
Yea its interesting. Note that this is still irrelevant of the fuel conditions you may be seeing. Meaning if there is a limit and its lifted it wont fix your condition if your condition is fuel related. It may just pull even more timing if anything ;-). Now that Ive fixed the fuel on mine its adding 4 instead which is great.Seems like mine is hard code to 4 as well
Truth, I can set it at 18 if you would like... LOL.Yea its interesting. Note that this is still irrelevant of the fuel conditions you may be seeing. Meaning if there is a limit and its lifted it wont fix your condition if your condition is fuel related. It may just pull even more timing if anything ;-). Now that Ive fixed the fuel on mine its adding 4 instead which is great.
Just realize ProChargerTECH lowkey called me a retardI wouldn't be beating on it with that kinda knock retard.
Again, normally here on good QT 91, our files will ADD at least 1 to 2 degees.
I mean.... "knock retard".... Not "knock" retard LOL.Just realize ProChargerTECH lowkey called me a retard
If you go to the data logging view a full spreadsheet will dump out all the data you can think of that the car is monitoring. That is all you need.Question to anyone. I just installed the Stage 2 with the nGauge also. Wondering about data logging. Are these the parameters already set in the nGauge so that its logging the right things? Just curious if I have to select them somehow? Sorry if that's a dumb question, just a noobie.
Thanks. I take it that was under the diagnostics and then data logging button. was in the car last night with the gauge hooked up, but car not running,but accessories on and didn't see a logging option. Guessing it was because my he car was off. I'll give it a go today. I did see under gauges I could select one and see a log getting generated, but was half guessing it was only recoding that gauge. Thank you.If you go to the data logging view a full spreadsheet will dump out all the data you can think of that the car is monitoring. That is all you need.
If you are in the gauges mode and initiate a log, it will only log the data on the screen.
In the full data logging mode there really isn't much else you need to use to tune. There are SLS ways other niceties but otherwise the normal data log will pull everything needed. And yes all the field are Pre set
I took a look, however you're missing some data points I'd like to see. You should log KNOCKR, lambda 1 & 2 or AFR 1 & 2, and finally throttle command. However looking at the log it seems like it is pulling a lot of timing.Hey can someone interpret these for me? Pretty short logs. Up a street from a stop I think into 3rd gear, then then back before hitting a light. Hope there is enough data to tell something.
I'll send to procharger, but it's the weekend and I just want to know the engine is being treated nice, lol.
Can someone tell me anything? Want me to take longer runs?
Thanks.
I was just coming back to edit my post. So I am opening your file compared to mine and saw those missing parameters. I am unsure how to add these to the ngauge as something to record. What was captured was I guess the default from me clicking on the gauge screen and starting a log. Any insight on that?
Oh yeah, thanks a lot for looking. I saw the + values in the SPARKADV and - in LTFT1(%) and didn't know what to make of those.
Not sure if you want me to keep asking these questions in your thread or not, but one more, then I can create my own thread if it makes more sense. Seems like you've been giving me more than my fair share of help. So I found some nGauge instructions finally. I was looking the last few nights and found odds and ins, but am attaching a set that might help someone down the road.If you're just using the gauge mode you can just add those missing ones by setting them as gauges and then logging. Just keep RPM, add KNOCKR and and throttle command. If those are missing from the options, you can rescan to get them.
