- Oct 7, 2014
- California
- Website
- www.modularmotorsportsracing.com
- Worlds Fastest & Only 5 second Coyote
bump
Pm sent$60 shipped. Paypal is [email protected]
Ordered one. Does this come with Torque specs or can you share that here?bump
Damn I totally missed that. :cheers:110 on the torque. It's on the washer.
Will this bolt work on the procharger stage 2,eight rib system??.I cant see it being designed for both the systems that use the factory belt and systems that use an additional pulley.Need to know before i buy this.bump
bump
If the factory bolt fit, the mmr will also, if your supercharger kit was supplied with a new bolt, our bolt will likely NOT fit.Will this bolt work on the procharger stage 2,eight rib system??.I cant see it being designed for both the systems that use the factory belt and systems that use an additional pulley.Need to know before i buy this.
NO, balancer depth is set by it bottoming on the crank gear which bottoms on the crankshaft.Does this washer also set the depth of where the stock or ATI balancer should sit on the crank snout?
I just got the MMR bolt and washer. So after removing the APP bolt and before installing the new MMR any extra silicone from the keyway left on the snout face must be removed completely I imagine. Have you had any experience with interference issues with the washer because of the silicone.
