Epiphany
It wasn't until someone mentioned that their e-brake handle was vibrating while making contact with it that I wanted to look at my own car. Since day one, before any mods were done, I've had a small amount of NVH that emanated from the driver side A-pillar area (in other words, the metal structure that sits between the windshield and the side window glass). Since I just added a Borla/FRP cat back, I wanted to run the car to burn off some of the assembly/manufacturing oils on the tubing anyway.
So I documented the range in a few different videos, showing the tach so that you can follow when it happens. OF NOTE - in the first two videos, both windows are rolled all the way up. Resonance begins at around 3200 rpm, sounding like loose coins in a tray, and then shifts to what sounds like a trim panel vibrating. It is over by 4500 rpm.
[ame]
Another clip just to verify. Same resonance range, windows rolled all the way up.
[ame]
Something that caught me off guard - when I rolled the windows down the resonance went away. Difficult to express in a YouTube audio clip based on a recording on a cell phone but I think you get the idea. In person it is clearly gone and not just washed away due to the exhaust system now being more audible. I switch from "quiet" to sport mode at the 27 second mark so that you can get a taste of the new exhaust system.
[ame]
I asked my good friend Rick from TMO if he could test the same range, windows up and windows down, to see if he could replicate what I saw. He found that his vibration did not go away with the windows down but he commented that the vibration that his car has been exhibiting is in the exact same range.
In a perfect world, each and every GT350 would be the same (and they wouldn't have any NVH). But they aren't. I'm honestly interested in what everyone else sees in that range. Resonance or not?
[ame]
[ame]
[ame]
