- Dec 8, 2014
- San Luis Obispo, CA
- 2002, 2006, 2015 Mustangs
2015-2017 X-Pipe Resonator Delete Mustang GT
J&M Products has engineered and released a 304 Stainless Steel X-Pipe Resonator Delete Part # 68005, designed to work on the 2015-Present GT Mustangs, equipped with the Coyote 5.0L DOHC V8 engine.
Manufactured from 2.5″ diameter free-flowing mandrel bent 14 gauge, 304 Stainless Steel (not the cheap 409 variety). Replace that restrictive factory resonator with a free flowing X-Pipe, helping to improve exhaust flow for more horsepower, torque and overall performance.
Installation requires cutting and removing the factory center section. This new X-pipe reuses the two factory clamps found on the front of the stock resonator, J&M supplies the two new clamps for use on the rear section after the appropriate cuts have been made. Best of all it reuses the factory catalytic converters saving you money, keeping you smog legal.
Features and Benefits:
- Converts Factory “Resonator” Mid-Pipe to an “X” Pipe
- Improves Exhaust Flow and Sound
- 304 Stainless Steel Construction, not the cheap 409 variety
- Cut and Clamp Design
- Reuses Stock Catalytic Converters – Smog Legal
- Fits All 2015-2017 GT Mustangs
- Flows More Than OEM Resonator
- Easy Do-It-Yourself Installation
- Much Lighter than OEM Resonator
- Includes (2) New Rear Band Clamps
- No welding required
Check out the article below regarding the difference in 304 and 409 Stainless Steel from our friends at Summit Racing.
https://www.summitracing.com/expertadviceandnews/professoroverdrive/answer/3932
