CJ Pony Parts
- Dec 21, 2015
- Harrisburg, PA
- Website
- www.cjponyparts.com
- A large variety of Mustangs across all generations
These sets of Velgen Classic5 wheels are currently available and IN STOCK at CJ Pony Parts, ALL finishes and sizes!
Set of Velgen 20" x 9" and 20" x 10.5" Matte Silver Classic5 Wheels
Set of Velgen 20" x 9" and 20" x 10.5" Matte Gunmetal Classic5 Wheels
Set of Velgen 20" x 9" and 20" x 10.5" Satin Black Classic5 Wheels
Set of Velgen 20" x 9" and 20" x 10.5" Satin Bronze Classic5 Wheels
As you would guess, the Velgen Classic5 wheel has a bold 5 spoke design and each color option features a brilliant finish. The 5 spokes start with a thick base in the center of the wheel and taper out as they extend to the edge of the wheel. A recessed lip sits behind the spokes to give the wheel some depth and added design. The rear 10.5” Classic5 will feature the deepest concave out of the entire Velgen line up, with a mid-concave for the 9” fronts.
The 20" diameter wheel provides a large amount of clearance for big brake kits and has no problem fitting around factory 15" Brembo brakes. These Velgen wheels require a hubcentric ring for installation which is included with each wheel.
In our 2015+ Mustang Specific Velgen Classic5 Wheel Kits you will recieve (2) 20" x 9" Fronts and (2) 20" x 10.5" Rears. The front wheels feature a +32mm offset with 6.26" backspacing while the rear wheels have a +45mm offset with 7.52" backspacing. Each wheel will include a color matched center cap and requires the use of small diameter lug nuts, see P/N: WHLLN16 or WHLLN17. The large OEM style lug nuts will NOT work.
Click HERE to see all of our tire kits that we have put together for the 2015+ Mustang. When purchased together, you have the option of taking us up on free mounting and balancing. We also have several TPMS options that when purchased along side of your wheels and tires, we can install them for you at no charge. To top it all off, once they arrive at our facility, these will ship with Free Standard Ground Shipping on orders shipping to anywhere inside the contiguous United States!
Velgen manufactures their wheels using a low pressure casting process. This casting process uses positive pressure to push molten aluminum into the mold quicker. Low pressure casting improves the mechanical properties of the wheel for a denser finished product over gravity cast wheels. Low pressure casting has become one of the most common casting processes approved for wheels sold to the OEM market. While low pressure casting has a slightly higher production cost over gravity casting, the end result is a much higher quality product. Once the Classic5 wheel has been manufactured, Velgen puts the wheel through a variety of quality control tests that include radial testing, impact testing and fatigue testing.
*These wheels are NOT intended for use on the GT350 or GT350R.
[MENTION=11003]Velgen[/MENTION] has not yet released weight specifications on these wheels and we currently do not have any plans to offer the 19" options once they are available.
Available in your choice of Matte Silver, Matte Gunmetal, Satin Black or Satin Bronze.
Please vote in our poll to tell us what your favorite available finish is!
Feel free to hit me up with any questions! :cheers:
