Are you trusting your TPMS or a pressure gauge?
GA
Reason I ask is because the TPMS reads 2-3 psi higher than my gauge. I'm trying to prevent having the tires overinflated.
What has been your experience?
stang1971
kcmo
2018 Premium Plus Magnetic GT
I have a Matco Digital Gauge and it reads the exact same as my car.
DarkestHour
GA
Hmm. Maybe I'll grab another gauge and see if it matches my TPMS or the gauge I already have.
jbailer
Joe
We've had SO many discussions about this. I'll ask a simple question, are all of your TPMS readings 2-3 psi higher than your handheld gauge reading? I'm betting the answer is yes. The TPMS is just a digital gauge that's value is transmitted to the computer for display. If you had 5 gauges and 1 of them read differently, which would you think is bad?
DarkestHour
GA
That doesn't mean the TPMS is accurate. A better test is several different gauges and if the differing ones agree. Four of the same is not equal to four of different.
Burkey
Australia
Both sets of my TPMS agree with the digital inflator at the local service station, which agrees with both of my pressure gauges at home....one of which I used when racing karts. 40psi max display, HUGE face (allowing setting in 0.25psi intervals) and checked against several other gauges for accuracy...
YMMV but I couldn't be happier with the accuracy.
JohnD
Legend in his own mind
beyond the pale
2023 Mach 1 track day car
I use my pressure gauge which I know is accurate to set the tires cold. I just monitor that with the TPMS. I'm looking for 2-3 lbs higher warm, and that's what I typically see. That's on the street, track use is totally different and way more complex.
DarkestHour
GA
Thank you both for your inputs. It looks like my handheld gauge may be reporting a bit low then. I will just do what TPMS says.
VinnAY
Kansas City
18 Camaro 1SS/1LE
Id read a quality dial gauge over the TPMS every day of the week. TPMS is just a substitute for being lazy.
jbailer
Joe
It has nothing to do with the level of effort. digital gauges in general are way more accurate than analog gauges. Can you buy a very accurate analog gauge? Yes, absolutely but you can buy a even more accurate digital gauge. The accuracy of the TPMS (digital gauge) is typically +/- 1 psi which is more than accurate enough for street use.
I'm guessing everyone uses a handheld gauge to fill their tires. I just can't imagine a way to use the TPMS logistically to accomplish that.
jbailer
Joe
Sure they are, they are 4 separate gauges. Each of the digital TMPS gauges are typically manufactured to +/- 1 psi accuracy. If you have 4 of them reading within 1-2 psi and your dial or any handheld gauge reads differently, it's the handheld that is off...
