It's really easy...make sure you have your car connected to your home wi-fi and it will OTA update your Sync 3 to the newest software. I ordered my USB module from White Bear Lake Ford they sell all parts at 10% over cost. Replace the USB in the glove box and plug your iphone in and your done! Apple Car PlayOwn a 2016 Tech. Anyone know if there is a way to upgrade to SYNC 3 plus Apple CarPlay?
having same issue. tried wifi upgrade and nothing. Then attempted to update via downloaded link and 32gb usb and got "upgrade failure. not enough storage space to proceed." not sure what to do?Would really like to know the details of the process you used. This did not work for me at all. I connected to house wifi but nothing happens. No automatic update begins. What did you do to initiate the update? Was the car running or just in full power accessory mode?
Do you have NAV?having same issue. tried bluetooth upgrade and nothing. Then attempted to update via downloaded link and 32gb usb and got "upgrade failure. not enough storage space to proceed." not sure what to do?
[MENTION=13582]kratty[/MENTION], did you have automatic updates on? I think there is a 'check for updates' button too.having same issue. tried bluetooth upgrade and nothing. Then attempted to update via downloaded link and 32gb usb and got "upgrade failure. not enough storage space to proceed." not sure what to do?
Can this come in as an auto update?For clarity, the official Ford upgrade has been released..follow link above.
auto update is on, connected to home wifi and it hasn't updated. Bought the new hub as well. The USB I'm using is 16gb, I believe the update file is only about 1.6gbs.[MENTION=13582]kratty[/MENTION], did you have automatic updates on? I think there is a 'check for updates' button too.
[MENTION=28613]ducatismo[/MENTION], I've read the USB can't be larger than 16 gib...
It seems that's what others are saying... I'll be giving it a try this afternoon and post what I get.Can this come in as an auto update?
I may have to use an extender to reach my wifi
Humm,,,,I've got nothing... Check out some of the later posts in the link above. You might find something there.auto update is on, connected to home wifi and it hasn't updated. Bought the new hub as well. The USB I'm using is 16gb, I believe the update file is only about 1.6gbs.
