jvm051
- Mar 30, 2015
- Maricopa Arizona
- 2015 DIB Mustang GT base with 3.55's
PMAS also makes a no tune version.
Two of my friends test the PMAS on a Mustang Dyno last weekend.Since ive been following the PMAS thread since day one, i suppose i might as well subscribe to this one as well. I plan on buying and doing a before and after dyno session. I just need my shop to schedule me in, they're booked up about 6 weeks out. (Blankenship)
I am assuming those gains are at the wheels, correct? That's insane gains from an intake alone, if so. If you could get your hands on a dyno sheet to upload, or have your friend join and share, that'd be great as well.Two of my friends test the PMAS on a Mustang Dyno last weekend.
One is a 2016 GT A6. The car best et is 11.57@120 with tune, stock airbox, BBK lth off road, Dynomax muffler and DR. On the dyno it gain 17hp and 21tq with the PMAS over stock airbox (back to back pull). The only modification is the incorporation of the table supply by PMAS for the mass.
The other car is a 2011 GT A6. Best et is 11.76@119 with tune, cat delete and DR (stock airbox, stock muffler). With the same method (back to back pull with only incorporation of the new mass table on the tune) it gain 16hp and 21tq over stock airbox.
The best is that the gain is from 2,500 to 6,500, not only at the peak.
Conclusion, I bought my third CAI (after the JLT and the Steeda) I hope this one is the good one. If not, my wife will kill me :doh: Next step track time!
Equally if people didn't question things logically there would be a lot of suckers in the world from unscrupulous products.
While there is a bigger tube, the throttle body is the restrictor at a certain point. Is it in this case? Idk
It's like pouring water through a funnel, the bottom of the funnel (the throttle body) can only handle so much volume even with a larger cone top portion until the bottom of the funnel need to get bigger too.
There is no "ram air" effect here forcing the extra air to the opening of the throttle body either (the inlet in the grill is also stock size so the same volume) since it's an open box (no pressure).
If I am reading this correctly, Y is AIR FLOW and X is PRESSURE DROP?Here is a flow test of some of the popular intakes.
X and y yes. And no. It shows for any given flow our intake has the least pressure drop and out of all the intakes tested the stock has the greatest pressure drop (restriction) for any given flow.If I am reading this correctly, Y is AIR FLOW and X is PRESSURE DROP?
So according to the data, of the intakes tested--your unit has the highest amount of air flow and the stock unit loses the least amount of psi through the power band?
Please correct me if I misinterpreted.
Ah thanks for clearing that up, I had a feeling it didn't make sense.X and y yes. And no. It shows for any given flow our intake has the least pressure drop and out of all the intakes tested the stock has the greatest pressure drop (restriction) for any given flow.
In other words, it takes a lot more flow through our intake to get the same pressure drop as the stock intake.
But, but, but it can't be, the stock intake from Ford is perfect and tubes shapes, smoothness and bends don't have anything to do with restrictions...X and y yes. And no. It shows for any given flow our intake has the least pressure drop and out of all the intakes tested the stock has the greatest pressure drop (restriction) for any given flow.
Can we please have a normal discussion about intakes without people acting like kids? This is a good topic with hard data. Don't ruin this thread with the same nonsense the other one degenerated into.But, but, but it can't be, the stock intake from Ford is perfect and tubes shapes, smoothness and bends don't have anything to do with restrictions...
