Replacement Base Model Radio Panel/Bezel
Mulestang
Jacksonville, FL
2015 Mustang
I've got an opportunity to pick up a complete stock 4" display radio panel for dirt cheap. I've considered getting it to hold in the event I remove my TomTop, so I won't have to disassemble it an replace the rubber key backing. So the question is....if I do pick up this replacement panel, will it be plug-n-play, or will it have to be flashed to the car to make it work? Thanks.
soldier989
Columbus OH
2017 GTPP Premium
Did you flash your car for any reason to get the tomtop to work? You shouldn't have needed to. So going back to a 4" screen should require no flash.
Mulestang
Jacksonville, FL
2015 Mustang
No flash. Just removed the stock radio panel to install the TomTop unit.
