Rebellion
Yeah, the sp085 is as close as it gets. I would have preferred something slightly softer, actually the rate combination that I like the most is the Steeda Extreme, but then the problem would be the drop. I really like the sp082/89 drop and looks, the closest one can get with a stiffer rate and same drop was the GT350R for front and sp085 for the rear. The actual drop should be really close to the sp82/89.Hmm... this is the only spring that comes close to matching the spring rate for the GT350 rear spring. In a way, it is somewhat better for folks that want to minimize the rake on their car as the drop is almost dead on with the 0.61" drop from the GT350 front springs.
I presume you could go with something softer in the rear but now you are messing with the ratios and will change handling characteristics. I'm thinking if you are ok with going from 160/165 up front to 240 in the front, a stiff ride isn't your concern.:shrug:
