Those with a GT350 mani, what RPM are you launching at?
jvm051
Maricopa Arizona
2015 DIB Mustang GT base with 3.55's
MT82 cars on slicks. What is your launch RPM with the GT 350 manifold? Also what RPM have you found is the best shift point?
Thanks in advance!
GTBOB
Fairfield Township, OHIO
Bob
'18 GT, Royal Crimson, 10 speed, Active Exhaust
5500-6000rpm launch depending on track condition. Shifting between 7500-7800.
Rhamlinii
Baltimore, MD
Ronald
2016 Mustang GT (Base)
V8EATR
MIDWEST
2015 GT PP
I find the best times come from 7800 shift points. Launching is a bit trickier than with the stock mani, I have radials and never side step the clutch and I don't like to tow my shit home but best 60' with the GT350 mani is 1.70 slipping it around 5500 or so.
poncho@home
GettingOld
Laval, QC
2017 Mustang GT Premium
V8EATR still on stock axles?
poncho@home
GettingOld
Laval, QC
Yessir. I did consistent 1.65 sixty foots with the stock mani using launch control but with the new mani, 4500 isn't enough.
Launch control with drag radials? On a GT?
poncho@home
GettingOld
Laval, QC
Yes, it has launch control, its a PP car. Its works pretty good at the track with radials.
Good to know that it works well with drag radials.
I am trying to decide whether to go drag radials or bias ply. While I prefer the simplicity of a drag radial setup, I want to get as consistent at the track as possible. I don't really care about the ET as much as winning rounds.
I have all winter to think about it, for now I am going to try my brother's Nittos off his 2003 Mach 1 and see what that can yield before winter.
kcc0521
Falls Church VA
Bo
2015 Black GT PP
If you are after consistency go with a bias ply tire. Drag radials on a stick car are difficult. It is a fine line between good launch, bog and wheel hop. I had nto5r on my stock PP wheels and was able to run multiple 11.6-11.8 at 118 mph. I went 11.40 at 118 on slicks.
poncho@home
GettingOld
Laval, QC
The only issue with the bias ply is that I also need front skinnies bias ply to go with them. That would mean 4 swaps at the track. Might be worth it.
Braski
Lancaster, PA
Traded 2015 Blk GT Prem PP on 2019 Corvette GS 2LT M7
The last time I went to the track I drove down on the skinnies and put the slicks on once I got down there. The car handled fine at posted speed limit speeds. I'm probably gonna switch to MT ET street R bias ply so I don't have to swap anything at the track. I ran drag radials on all my other cars and I am really enjoying running slicks/bias ply now that I'm use to them!:)
