Steeda Cold Air Intake Kit ProFlow Without Tune GT 2015-2017
Status
Not open for further replies.
CJ Pony Parts
Harrisburg, PA
www.cjponyparts.com
A large variety of Mustangs across all generations
Steeda ProFlow Cold Air Intake Kit with No Tune Needed for 2015, 2016 and 2017 GT Mustangs.
Are you looking for an aftermarket cold air intake that'll help open up your 2015-2017 Mustang GT's intake system and allow it to breathe easier and more freely? Something that'll be easy to install and won't require a lot of time, money and hassle on your part? Something that'll give your S550 plenty of HP and torque gains without a tune? If so, you're in luck! Check out this Steeda ProFlow Cold Air Intake Kit, now available from CJ Pony Parts!
[ame="[MEDIA=youtube]id=S_y673Ari-k;t=64[/MEDIA]"]
Features & Benefits:
- Outperforms All Other Cold Air Intakes on the Market Today
- Opens Your Mustang's Intake System and Allows it to Breathe More Freely
- More Than 22 RWHP and 18 ft/lb Torque Gain without a Tune
- Increases Power at All RPM Ranges, Not Just at Peak Power
- Lower Intake Air Temperatures (IAT) at Cruising Speed Compared to Competition
- Precision CNC Mass Air Housing for Clean Mass Air Signal that Results in Smooth Off- to On-Throttle Acceleration
- Large Surface Area High-Flow Nanofiber Air Filter and Steeda's Famous "Race-Tested" Velocity Stack Entry
- Advanced Heat Shield and Durable Rubber Gasket
- Easy Bolt-In Installation
- Keeps Sound Tube and Factory Cold Air Ducting
- Includes Cap for Sound Tube Elimination
- Works on Manual or Automatic Transmissions
Tech Tip: For 2017 GT Mustangs manufactured after 9/16, vacuum for the CMCV’s (Charge Motion Control Valves) is no longer picked up from the intake tube. This will require a plug to be used with the unused port/fitting on your new cold air intake tube when installing on all 2017 GT Mustangs built after 9/16 only. The production date on the vehicle (month/year) is located on decal in driver side door jamb.
This Steeda 555-3193 ProFlow Cold Air Intake Kit is one of the best available today! As a matter of fact, it outperforms just about every other cold air intake on the market. It'll open your S550's intake system and allow it to breathe more freely, which means more HP and torque gains for you! You'll get more than 22 RWHP and 18 ft/lb torque gain without the need for a tune. This ProFlow Cold Air Intake Kit will increase your Mustang's power at all RPM ranges, not just at peak power! Not only that, the intake air temperature is lower with this kit compared to other kits out there. The cold air intake kit itself comes in a CNC mass air housing for a clean mass air signal that'll result in smooth off-throttle to on-throttle acceleration. It also comes with a large surface area high-flow nanofiber air filter, an advanced heat shield and a durable rubber gasket, plus it uses the sound tube and factory cold air ducting. It also includes a cap for sound tube elimination! An easy bolt-on installation, this cold air intake kit will work on Mustangs with an automatic or manual transmission.
*This cold air intake is not approved for use in California or states that require a California E.O. #.
Please Note: If you’re looking to squeeze out even more power from Steeda's S550 cold air intake, Steeda's S550 CAI utilizes a removable restrictor that allows you to benefit from immediate HP/TQ gains. Doing this will require you to run an aftermarket tune/calibration, which is not included.
Order a Steeda 555-3193 ProFlow Cold Air Intake Kit with No Tune Needed for your 2015, 2016 or 2017 GT Mustang from CJ Pony Parts today!
[ame="[MEDIA=youtube]K-OLFUxuETc[/MEDIA]"]
tj@steeda
Timothy
Great part ... from the fitment to the quality, anyone looking for a CAI will not be disapointed in the Steeda unit!
TJ
Status
