F*ck your :ford: warrantyyou crazy heads are actually going to make me remove my bumper and take a dremel to my lights aren't you???
:amen: :cheers:sexyness > everything else
You are a genuine Italian :cheers:sexyness > everything else
I had the flicker concern with the switchbacks, but I do not have the worry with the DD tribars and their latest version of the drivers.No, that was not the case with mit boards. The old driver got the problem that sequential turn signals did not work when the engine was running. the new driver fixed that but still got the flickering problem.
I got the hint to try to unplug the OEM parking lights to get rid off the flickering from the EU sub here, but he had the same problem as me.
But EU mustangs every really tricky in terms of electronic. Never could switchbacks get to work because of flickering issues while the same setup worked fine on other cars. It was really annoying
John I don't want to disappoint you, but eventually you will have to replace them. They do not offer a robust connection. When I removed the T-Taps I realized that they barely make a connection with the wires, so due to the vibrations of the car while moving, these connections most probably will stop working. I believe it's a matter of time before they go bad.No problem so far with the T-taps from DD on my car. But to be sure, I've put a lot of eletrician tape around the connexion
For warranty cases, I may suggest you to order directly by Diode Dynamics : https://www.diodedynamics.com/store...tang-switchback-drl-led-boards/category/1451/soo... is this the part I need ?
http://www.cjponyparts.com/switchba...-board-kit-asia-eu-spec-2015-2017/p/DRLLED10/
(sorry if it's linked previously I don't have time right now to go reading back...)
Sadly no discount by Diode Dynamics. But, bad timing for you, last week they had a 20% discount code on everything ...hum, don't scare me now... do we have any discounts for Diodes shop?
