Unimpressed with lowering springs...what's next?
Palifter21
Pennsylvania
2017 Mustang GT
Hey everyone,
Recently installed SR lowering springs on my 2017 GT auto coupe. These springs provide a 1in drop on all 4 wheels. I also did a 25mm wheel spacer on the rear wheels. Although this combo made the car have a much more appealing stance, i'm not thrilled with the handling. Not sure if its worth noting but the car has a MBRP street catback, Lund 93 tune and JLT cai.
I almost feel as if the springs are too much for the stock shocks...if that is such a thing. The car also has a Steeda strut bar up front and upgraded vertical links by SR performance, they greatly reduced wheel hop and make the back end much more confidence inspiring when spirited driving takes place.
So my question is, what can I do to aid in handling and overall feel? Is it time to replace the stock shocks? Something else?
Thanks in advance!
MaskedRacerX
Driver
Vilano Beach, FL
DT
'21_JWS4XE / '21_TM3P
No experience with SR, but my BMR SP080s - in addition to looking fantastic - also substantially improved the handling, and the "feel". They're linear (vs. the OEM progressives), and specifically designed to work with the OEM shocks.
Note that I have PP car, so my shocks and stabilizers are a bit improved over your non-PP car.
Shocks would clearly improve things, but I'd make sure to get a good match for your spring rates - I'd reach out to BMR and Steeda, with the existing spring specs, give them an idea of your goals.
Some shocks and a set of aftermarket stabilizers and you can get a real tight setup, though you'll start encroaching on "street comfort".
tj@steeda
Timothy
Hey everyone,
Thanks in advance!
Shoot me an email & we can get you situated ([email protected]) - we have a great set of fixed shocks that can pair well with the SR springs.
I look forward to hearing from you!
TJ
NightmareMoon
2016 Mustang GT PP
Yeah those springs rates are going to be a bit much for the stock shocks, even the PP ones. You need stiffer shocks to dampen those increased spring rates.
1in drop also makes it hard to stay off the bumpstops, i hope you trimmed yours when you put the springs on.
Inthehighdesert
NM
Charlie
I installed my steeda springs on my 16 vert with 3500 miles on the car. So, the factory struts were still pretty much new. The dampening of the factory struts wasnt up to the springs. It wasnt horrible but it was obvious. I changed them to the steeda non adjustable setup with the rear billet mounts shortly after. There was a noticeable difference between the two. The latter was much more controlled and predictable.
Norm Peterson
corner barstool sitter
Norm
'08 GT #85, '19 WRX
It won't cost you anything except a few minutes time and a little sweat to pull those rear spacers off and see if the situation improves. Adding spacers adds leverage to the loads that make suspension bushings distort. There may be other effects.
Not changing out the shocks and struts has moved the relative amount of damping down (away from where best tire grip lives). It would be giving a softer ride that could be acceptable if you're OK with the car moving around more on its suspension.
Norm
Shermanator
Pennsylvania
2017 Mustang GT
Thanks for the feedback thus far. I did take off the spacers recently, has no negative effect.
I’m thinking it’s time for shocks to be upgraded. I have 2 questions:
1. Any feedback on the KONI orange non adjustable shocks? Anything comparable in price?
2. Do all 4 shocks need to be replaced at the same time or can I do the rears first, wait a few weeks to assess how impactful they are then do the front?
tj@steeda
Timothy
Shermanator
Pennsylvania
2017 Mustang GT
Thanks TJ, I like the price point and reviews on those shocks. I’m going to shoot you an email.
SVT-DADDY
World's heaviest S550
CT
2015 GT Convertible
I did the same thing as you, except with BMR 089. Handling actually deteriorated as the stock non PP dampers weren't up to the task. I got a good deal on PP dampers and the car handles much better.
However I will say that I think your on the right track with TJ. Kinda wish I went that direction.
texasboy21
Houston
2017 GT PP. 2005.5 Audi A4, 1983 Silverado
Suspension components have to work in harmony. A proper set of shocks should bring the handling back to normal/improved.
Shermanator
Pennsylvania
2017 Mustang GT
Narrowed it down to Steedas non adj shocks and Konis non adj (Orange shock) along with camber bolts to help with negative camber after installing the SR springs with a 1in drop all around.
I’m really on the fence here. The Koni has the lifetime warranty while the Steeda is slightly cheaper with the forum discount. I’m guessing both are a pretty significant upgrade over the stock non PP GT shocks and I should just choose one..?
texasboy21
Houston
Koni orange wouldnt be considered an updated, and likely are less dampened than the OE PP shocks.
Koni yellow (sports) are to be matched with lowering springs. That said, in my experience Bilstein B8s (sports) are far superior to Konis.
tj@steeda
Timothy
Steeda has a lifetime warranty too - send me an email at [email protected] and finalize your search :).
Shermanator
Pennsylvania
2017 Mustang GT
Haha just when I thought I had it all figured out.
I had bilsteins on my 2017 Ram 1500 to level it and they were great.
