What you're looking for I don't think you'll find without a change in turbo. Even if the car is tuned and there is a small bump up top, it will still drop off at the same rate as the entire rev range has gained power. The power loss is a characteristic of the turbo, not the tune.Even if they kept the stock power levels but re-tuned it to hold power past 6k RPM it'd be a win in my book. Now that I've had mine a few months I find the dramatic power drop off past 5k RPM to be a real downer when trying to have some fun.
Power wise, it's just a little shy of where I think it should be. It needs to be strong enough across the RPM range to push you back in the seat when you get on it. With the stock tune, it doesn't.
True, but at least with a tune the power is much higher. Big turbo is a couple years out for me, unfortunately.What you're looking for I don't think you'll find without a change in turbo. Even if the car is tuned and there is a small bump up top, it will still drop off at the same rate as the entire rev range has gained power. The power loss is a characteristic of the turbo, not the tune.
Yeh, but if the TQ increased so did the HP, at least at the peak TQ rpm, maybe it still drops a lot as rpm grows so max HP is same.In the 2018 information that was released, Ford stated that there is an increase in HP and torque for the GT but only an increase in torque for the ecoboost. If they were going to increase the horsepower as well, I surely think they would have mentioned it in the release as well.
