Rear PP 9.5 in wheels clear Brembos?
Silver50Pony
Westchester NY
2015 5.0 PP Ingot Silver
Has anyone threw another pair of 9.5 inch PP wheels that came stock on the rear onto the front with a set of 275 or 285s without clearance? Or anyone with American muscle PP replica 19x 10s on front clear the Brembos?
Grintch
Hunstville
2015 GT PP
Stock 9.5 ET52 wheels hit the strut without a spacer.
Paul@PKAUTODESIGN
The Wheel guy
Los Angeles, California
WWW.PKAutoDesign.com
Paul A.
2016 Shelby GT350 Tech Pack #G5531 Avalanche Grey
It will work you need a 5 mm spacer to place upfront and your good.
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
N4SM Team
Just keep in mind that when you do end up using spacers that you get at least 6 turns on your lug nuts to ensure you are safe. If you have any further questions, feel free to contact. We have been custom making spacers and adapters for over 15 years for our clients. :cheers:
Paul@PKAUTODESIGN
The Wheel guy
Paul A.
A 5 mm spacer will still provide the safest amount of turns without the need of a et lug nut.
Your good brotha
Paul@PKAUTODESIGN
The Wheel guy
Paul A.
Paul@PKAUTODESIGN
The Wheel guy
Paul A.
Thanks, do you know if a 285/35 will fit with no rubbing anywhere or should I run a 275 to be safe?
I say stick with a 275, it's a 9.5" wheel you can get much out of a 285 from it
Grintch
Hunstville
2015 GT PP
Problem is ET52 - 5mm spacer = ET47 is still a good bit off the optimum of ~35-40 to fit wider tires.
Some have used 285s on the front with the stock 19x9 ET45, so it should work.
Paul@PKAUTODESIGN
The Wheel guy
Paul A.
You are correct, its not optimal but it does work out if someone wanted to do that.
