Lisa@Borla
- Apr 19, 2016
- Website
- www.borla.com
- Lisa
New BORLA XR-1® Tuner: Add 40HP to your 2015-2017 Mustang 2.3L EcoBoost Instantly!
The Borla XR-1® Tuner represents the latest technology in vehicle performance electronics and is engineered to improve torque and horsepower in turbocharged cars.
Find out more at https://www.borla.com/products/xr-1-tuner/.
Legal only for racing vehicles which may never be used, or registered, or licensed for use upon a highway.
INSTANT 40 HP for Mustang 2.3L EcoBoost!
Offroad Legal only for racing vehicles which may never be used, or registered, or licensed for use upon a highway.
The XR-1® Tuner represents the latest technology in vehicle performance electronics and is engineered to improve torque and horsepower in turbocharged cars. It features a fast 48Mhz processor and SMD construction for best resistance to shake and vibration conditions as well as improved EM and RF performance.
Each XR-1® Tuner application has been tuned and tested to enhance your vehicle’s driving dynamics, while keeping OEM protections and drivability intact. The software is specifically tuned for, and the hardware is designated for each vehicle to provide maximum benefit.
The XR-1® Tuner allows the engine to produce up to 70 lb/ft of torque and 40hp more than stock.
It is very easy to install the XR-1® Tuner, since it has been designed as a plug and play device, it can be installed in 10-15 minutes in most applications. It is also quick and easy to disable the device; simply plug in a by-pass connector to return to factory power level. You can plug in at the track, unplug for the street. Its stealth design leaves no trace in ECU flash memory and it is not affected by dealer updates to the ECU. The XR-1® Tuner can be completely removed in 10-15 minutes if you want to return the vehicle to stock for any reason.
The kit includes a stainless steel mounting bracket, all necessary wiring and easy-to-follow instructions.
- Simple DIY installation.
- Quickly enabled and disabled. Plug in at the track, unplug for the street.
- Stealth design leaves no trace in ECU flash memory.
- Includes stainless steel mounting bracket, all cables and easy-to-follow instructions.
- Not affected by dealer updates to the ECU.
- For racing only.*
