GT350 FORScan Tweaks
jwooly68
DC area
2019 GT350R
Bet that tune IS related. Remove it from the car, and try again. I have heard some tunes have locked this out, but most of them do not.
You are correct. FORScan is not compatible with my Tune. So I have restored the factory tune and everything worked fine. Once I'm done I'll re-install the tune.
HizliBullet
GT350
Canada
Mustang
16 GT350, 17 Edge Sport
is there a forscan tweak that allows the fob to roll windows back up? we know it rolls them down but no up.
sweetchuck2001
Ohio
16 GT350, DIB, Tech package.
A big thank you to everyone who has contributed to this thread.
Just did the red splash screen, and added the transmission temp gauge.
kratty
DC area
'56 Victoria, Tahoe, '16 GT350
Which is the correct code to stop the double-honk on a 2016 Tech pack car? I see the following instructions, but neither are for Tech. Which will work?
BCM 726-41-02 0000 0001 0172 No Horn Exit When Running 2016 Track
BCM 726-41-02 0001 0001 0173 Double Horn Exit When Running 2016 Track
BCM 726-41-02 0000 0000 0070 No Horn Exit When Running 2017 Conv
BCM 726-41-02 0001 0000 0071 Double Horn Exit When Running 2017 Conv
Also, what's the likelihood that we'll be able to figure out how to set the default exhaust setting to Sport?
Thanks to all who've made this such a great thread!
Epiphany
Epiphany
Global
I like to disassemble things.
What numbers does your Tech car show?
GT_Dave
NE Illinois
1970 Mach 1 408EFI , 2016 GT350
My 16 Tech car showed the 0071 digits, I programmed for the 16 Track Pack 0072 and it works fine.
Epiphany
Epiphany
Global
That's what I would have thought. I'd still like to see what numbers he has now.
live2ride90
Santa Cruz, Cali
Jared
2017 GT350R
Connection Issues
Well since I messed up knee I had some time to play with this over the weekend. I got my laptop to connect to OBD MX that is listed on here one time. I wanted to go double check what I was doing so I left and came back and I could never get it to connect again. I deleted the ODB from my laptop and tried to re add it and it will not even connect now. I reset the OBD and multiple restarts on my laptop and nothing. I tried 3 different laptops and when I can get the OBD added on my laptop I still get the ELM error, not sure what else to try. Any other tricks I can try that anyone might know? Any help would be greatly appreciated, thanks!
sweetchuck2001
Ohio
Not sure if you're connecting through blue tooth or wifi, but I had to hit the reset button on the OBD and refresh the blue tooth connection on my lap top a few times to get it to connect.
live2ride90
Santa Cruz, Cali
Jared
2017 GT350R
Sorry forgot to mention I was connecting through bluetooth. Yes I tried that multiple times with no luck. Just don't get why it connected once and now never again..
Screamer
Fla
Al
2116 GT350
You're not crazy. The car DOES do this to aide in smooth driving for non-drivers. It is very annoying, I noticed it from day one. This is turned off in the engine calibration, not with Forscan. A tuner can do this for you. :cheers:
On the older fords this was called dashpot function.
Mustang_GT
Martha Lake
Kevin
2016 Mustang GT PP - Triple Black
Fellas -
Anyone know if the code for turning off the 'sound enhancement' would be different on a 2017 R?
Thanks!
I used the As-Built setting that I found in the GT350 thread for my GT PP and passengers noticed right away. I have the GT 350 valence and Ford Racing exhaust on mine and didn't know if it would make a difference . It does. I had already removed the sound tube (which obviously yours doesn't have).
Module ACM Address 727-01-01 xxxx-x0xx-xxxx
Voodooo
SE Michigan
Scott
Carroll Shelbys Soul Lives Under My GT350 Hood
I haven't followed this thread much. I have 30 series tires and I'd like to possibly swap my rear gears. Will this allow me to correct my speedo or do I have to go with the whipple flare?
Thanks guys.
Mustang_GT
Martha Lake
Kevin
Tires
Thanks guys.
I believe so. There are guys here that show the calculation
jvandy50
H3249
AR
jason
22 TRX, 18 ZL1-1LE
Does this function have a name or you just say hey my revs are hanging too long? I need to ask lund to try again
