That's what I was thinking too. It looks like its being limited somehow. Torque would have to fall to keep hp flat lined with rpm rising, due toIs it possible torque management or traction control is kicking in?
It is tuned by Greg at Lund Racing via remote tuning. What is VCT? And OP mode scheduling?who is tuning the car? is it prochargers tune? that looks like VCT to me. the suto cars come with the OP Mode Predicted Scheduling turned off from the factory where the stick cars have them turned on. basically the vct does not follow the commanded tables. that chart looks EXACTLY like a chart where its turned off.
Well I didn't have that problem on the stock manifold with a D1SC. So it is not that. Cats possibly? And I pulled all the way to 7750 rpms.Diablomatt: I posed your thoughts to Lund. They assured me this was correct in my tune.
So the question is. Is this caused my the stock intake manifold or the factory exhaust manifolds and/or cats?
I either need to get LT headers of r the GT350 intake manifold. I just want to make sure I'm replacing the right one. I've still yet to see anyone's hp curve go flat like mine at 6400 RPM.
Mine with stock intake manifold and stock exhaust flat lined at 7k ...I had a problem with the cats , so I removed them ..HP and TQ did come up some but the motor still flat lines at 7k ... I'm sure a intake and headers will make more HP but I don't think it will fix your going flat at 6400..:shrug:Diablomatt: I posed your thoughts to Lund. They assured me this was correct in my tune.
Did you MAF lb/min rate increase when flatline? Mine goes up 14 lb/min from 6400 to 7500 rpm. Air fuel is constant. So that means I'm burning 14% more fuel and ingesting 14% more air but making less or the same power. That doesn't seem like a flow limitation in my mind. Seems more like a controlled limit. But of what kind I don't know.Mine with stock intake manifold and stock exhaust flat lined at 7k ...I had a problem with the cats , so I removed them ..HP and TQ did come up some but the motor still flat lines at 7k ... I'm sure a intake and headers will make more HP but I don't think it will fix your going flat at 6400..:shrug:
I would disagree...definitely sounds like a flow issue...on the exhaust side.Did you MAF lb/min rate increase when flatline? Mine goes up 14 lb/min from 6400 to 7500 rpm. Air fuel is constant. So that means I'm burning 14% more fuel and ingesting 14% more air but making less or the same power. That doesn't seem like a flow limitation in my mind. Seems more like a controlled limit. But of what kind I don't know.
Then why was Z06psi not have the issue with stock manifolds and cats?I would disagree...definitely sounds like a flow issue...on the exhaust side.
