S550Smoke
2015 performance pack gt (hpde/road course)
Located in Americus, GA
7000 miles, garage kept and built very solid
Exterior
Ford Racing deck lid
MMD upper/lower grill
Watson Racing rear tow
Dusold designs front tow
Anderson Composites carbon fiber hood (not installed)
Kohr Racing Carbon fiber hood
Sparco hood pins w/ both hoods
Trufiber carbon fiber trunk
Anderson Composites double sided carbon fiber duckbill trunk (not installed)
APR gt-250 race wing
Apr front splitter
gt350 fenders
aj Hartman aero canards
dusold designs custom race wing (not installed)
dusold designs custom splitter (not installed)
apex 18/9.5 race wheels with nitto nt555g2’s
Interior
Watson racing 6 point bolt in roll cage
Gt350 steering wheel
Oil temp gauge
Differential oil temp gauge
AutoBlip Box
SCT Tuner (Current Tune)
Lund NGauge tuner (Previous Tune)
Engine/tranny/drivetrain
BMR Adjustable Polyurethane Motor Mount Kit
Gt350 Manifold/tb
L&M intake only cams
Mmr oil pump gear
Mmr crankshaft sprocket
ATI harmonic balancer
Jms fuel pump booster control
Jlt cold air intake
Id1000 injectors
Stainless works headers and deleted cat h pipe
Mbrp race exhaust
Jlt oil separator (passanger/driver side)
Mishimoto coolant tank
Mishimoto radiator
Mishimotor oil cooler
Full tilt boogie racing differential oil cooler
AED tune
Mcleod rst twin disc 800hp/ lightweight flywheel
Sr performance braided stainless clutch line
Mgw race spec shifter
Driveshaft shop 800hp axles
Shaftmasters aluminum lightweight driveshaft
Canton road race oil pan
Suspension/Brakes
Steeda front/ rear sway bars
Steeda strut tower brace
Steeda transmission bushing
Steeda subframe support bushings
Steeda jacking rails
Steeda billit aluminum vertical links
Steeda g-trac k-member brace
Steeda irs subframe alignment kit
Steeda irs subframe support braces
Steeda clutch spring
Steeda brake lines
Steeda front/rear slotted rotors
Jlt brake cooling ducts
Sr performance bump steer kit
Sr performance adjustable rear toe links
Maximum motorsports caster camber plates
KW-V3 coilovers
Gloc brake pads
All stock parts/interior have 2500 miles on them and come with the car.
pm with any questions. Also have factory performance pack boost gauges if someone decides to want to boost the car. Probably forgetting parts. Selling this car to focus on 1 project. Thank you
***$ 30K*** for no reason other then I would like to sell now
Exterior
Apr front splitter
gt350 fenders
Interior
Oil temp gauge
AutoBlip Box
Gt350 Manifold/tb
Mmr oil pump gear
Jlt cold air intake
Id1000 injectors
Mbrp race exhaust
Mishimoto radiator
AED tune
Suspension/Brakes
Steeda brake lines
KW-V3 coilovers
Gloc brake pads
