A/C Drive Belt on ATI Super Damper (Whipple 10 Rib Belt Kit)
Vile_the_Bastage
of Clan Bastage
Midwest
Internet Legend
2015 Mustang GT Premium
Anyone have any luck getting the A/C Drive belt on a ATI Harmonic Super Damper? The method used for the stock pulley will not work on a ATI damper. Suggestions?
Vile_the_Bastage
Vile_the_Bastage
of Clan Bastage
Midwest
Internet Legend
Okay, apparently the zip tie method works. Remove one of the three bolts that secure the A/C pulley to the harmonic balancer. Push a zip tie through the bolt hole and pull the slack on the reverse side up so that you have access to it, but don't lock it. Feed the A/C Drive belt behind the harmonic balancer so that it rests against the crankshaft itself. Feed the slack around the ribs of the A/C pulley. Tightly secure the zip tie with the A/C drive belt inside (make sure that you have a bit of the belt sitting in the groves of the pulley). Rotate the crank pulley clockwise until the belt pops into place.
Roh92cp
Fort Kent Maine
Shawn
OW GTPP Whipple
I wish you had pics of this, cant seem to see what you described in my head.
