GT350 FORScan Tweaks
kgschrader
Magnolia, TX
www.spacecitypanteras.com
Kirby
20 GT350R LR217, 2017 Raptor, 20 720S, 71 Pantera
Kirby,
Ford (dealer) tells me there is one big harness for the aft end and it will plug into both sides. I believe this to be true. The two wires from the LH side and the two wires from the RH side all come into C405 (the connector attached to the evap; also the L/R exhaust solenoid wires come through C405 (and a ground wire)).
The harness that leads to C405 (on evap), comes through the trunk at the very back. Unscrew the four strap/tie down anchors, pull the trim bottom fwd, and then pull up. You'll see the harness penetrating the floor. The temp sensor harness comes down the left side and then, I'm guessing, goes under the back seat and through the floor.
I just connected all the leads from C264 and C215 to the pump and heated the sensor to 232F and the pump did not start. I am going to post in the diff cooler thread. Majorly disappointed.
That routing makes sense based on the other information.
Trouble is, that's a $500 harness from what I've seen...
As for the pump starting, did you have it hooked up prior to starting the car? Everything I've read about the PWM circuits seems to indicate that when the car is first started, the pump gets a full on signal to get it started, then it will go to the modulated state.
I've read that the pump will have too much initial startup 'friction' and won't just gradually turn on.
So, a further experiment would be to wire everything up like you had it, then start the car. I don't know that this works, just suggesting based on other information I've read. After all, it has one pin called RUN/START. Seems to hint at the above, also.
Good luck!
Kirby
  • Like
Reactions: jwb
barstowpo
Witness Protection Prog
Helena, MT
Gordon
2016 DIB GT350 Tech/Track hybrid, 2016 FPRS Car#17
You guys are amazing. I couldn't begin to figure this stuff out.
  • Like
Reactions: jwb
jwb
Saint Louis
2016 GT350 Tech Pack, Wht w/ blu
Good luck!
Kirby
Thanks Kirby,
I did connect everything with power off so I could double check before powering on. [MENTION=26358]mkonrad[/MENTION] did provide some insight/help on the OEM Diff Cooler thread. Perhaps the system needs to sit with the connections for a decent amount of time. I know some system things require time to "reset." Maybe this too. Also, before I tried the full up test, I did get voltage across the Batt and run/start leads. So I was optimistic.
Makes sense that the motor would start with full (width) voltage to overcome static friction and gain a little momentum. I would think that would happen when the oil temp hits its target; maybe not at engine start up.
Thanks,
her5oh
NW Arkansas
Anastasia
2016 Magnetic GT/PP
TPMS
Hey folks, I used ForScan to turn off the TPMS light on my F150, but I am trying to figure out how to do so on my 16 GT. Does anyone have any insight?
The F150 was 726-22-01 x0xx xxxx xxxx but that did not work on the Mustang.
Thanks in advance.
Leonard
Ohio
2016 GT350
I just put air in my tires and that takes care of the TPMS light.
Thanks in advance.
Gilby
Diamond in the rough
GT350, 98 Cobra
Anyone in NE ohio that might want to help me do this? I can buy beer, ha ha. I'd love to get the trans temp on the screen so I can monitor it.
Tank
9/11 - Never Forget
Above the Notches
G0853
Mustang_GT
Martha Lake
Kevin
2016 Mustang GT PP - Triple Black
Check sum
Ok guys I finally started playing with As Built. Looking to change my Splash screen and shut down screen to the GT one. I can switch it over in diagnosis but it doesn't stay on a restart. I know the strings to change but .....
So tried to use FORSCAN to change my Splash screen to the GT screen but can't fingure out how to change it. I can see the string but:
7D0-03-01 xxxx x4xx xxxx
7DO-02-01 XXXX XDXX XXXX (Mine has other digits in it)
If I change my string to that above, I get a check sum error message in a pop up window asking me to verify. I opted out on the change until I get an answer if I am doing this correctly.
Help
The check sum will be corrected by FORScan automatically.
VOODOO 6G
Ohio
Eric
2016 Shelby GT350
Where you at in N.E. Ohio? I'm in Randolph and am planning to do my car soon.
TxOilMoney
US
F150
I finally got around to some "tweaking" using the posted instructions. I was successful in deleting sound enhancement, double horn when exiting, and added the red splash screen and trans. temp to my gauges. But for some reason, I can't disable the seat belt chimes. I've tried with forscan and with the instructions in the owners manual. Each time, I get the 4 blinks at the end, which is the acknowledgement of a successful change. However, it still chimes. Any ideas?
Helmet
Korea
Dude
2016 GT350 Track Pack
Have you tried buckling up? :lol:
kartguy898
Ottawa, Ontario
2016 Shelby GT350 / 2016 F150 FX4
Any chance there is a setting to change the forward speed at which the rearview camera display shuts off on the (Sync) screen?
