2015+ S550 Mustang Forum (GT, GT350, GT500, Mach 1, Ecoboost) - Mustang6G.com 19 - Diode Dynamics - 1
Homepage Wiki MOTM Register Search Today's Posts Mark Forums Read Ford Bronco Forum Calendar Garage
Go Back   2015+ S550 Mustang Forum (GT, GT350, GT500, Mach 1, Ecoboost) - Mustang6G.com > 2015+ Ford Mustang Forum > Mustang S550 General Forums
Mustang S550 General Forums General topics related to the S550 6th Generation Ford Mustang
User Tag List
Reply
Thread Tools Search this Thread Display Modes
Old 10-16-2017, 08:15 AM   #1
DrGrabster
UK Member
DrGrabster's Avatar
Drives: I'd like an 18 in white please, with magneride.
Thanked: 146 Times in 115 Posts
iTrader Score: 0 reviews
Question 2018 Auto Start-Stop Technology?
I've not seen reference to it, but does anyone know if the 2018 GT gets auto start-stop?
The new F 150's are so equipped and it might be quite good, but I don't really want it in my Mustang.
__________________
Ordered 11/10/17 Oxford White GT Fastback, 10 speed Auto, Magneride, Tan interior .
DrGrabster is offline   Reply With Quote
Old 10-16-2017, 08:35 AM   #2
x_man586
Bodyman
Drives: 2016 Oxford White Mustang GT m6 2002 f150 SVT Ligh
Thanked: 43 Times in 28 Posts
If it is you should be able to turn it off right?
__________________
Ford Racing x-pipe resonator delete. Dynomax mini race bullet mufflers. Steeda clutch assist spring.
x_man586 is offline   Reply With Quote
Old 10-16-2017, 08:38 AM   #3
Kevin08
Kevin08's Avatar
Drives: Soon to be 18GT 401A
Thanked: 631 Times in 336 Posts
If anything the automatics would have it, and it's always something that can be disabled in mostly all equipped cars.
Kevin08 is offline   Reply With Quote
Old 10-16-2017, 08:41 AM   #4
Bravo
Drives: Just Looking
Thanked: 27 Times in 21 Posts
It's always something you can disable, but it's not always a feature that is permanently disabled. I know that in many euro cars, the feature has to automatically enable itself every time the car starts up in order to meet certain emissions standards in parts of the world.
Bravo is offline   Reply With Quote
Old 10-16-2017, 08:55 AM   #5
DrGrabster
UK Member
DrGrabster's Avatar
Quote:
All the F 150 trucks enable it each time the vehicle starts up.
Here is the sort of thing the truck owners do to turn it off automatically...
To disable the auto start/stop feature you need to jumper a wire on the on/off switch on the radio bezel. This will make the system think the button is pressed to off each time the engine is started. To remove the bezel just pull up on the tray on top of the dash. Remove the 2 7mm screws under the tray to loosen the radio bezel. Pull the bezel off by pulling from top to bottom. Either unplug the wire harness to the on/off switch or push the switch out of the bezel by pressing the tabs in on both sides of the switch and push it out. Jumper the purple and white wire by either splicing a wire between the 2 wires or shoving wire in the back of the harness until its secure and wont move. A piece of safety wire in the socket is less permanent and can be removed easily.
https://www.f150forum.com/f118/disab...p-good-332431/
__________________
Old 10-16-2017, 09:13 AM   #6
Timeless
RS Boost is Fun
Timeless's Avatar
Drives: 2016 Focus RS
Thanked: 9 Times in 7 Posts
It is on every Focus RS which is manual only, so I don't doubt it will be on every Mustang.
And if it is like the RS it cannot be permanently disabled and your routine will be at every start up to disable this along with putting the car is sport mode.
__________________
Current Ride: 2016 Focus RS
Wife: 2016 Mazda CX-5
Timeless is offline   Reply With Quote
Old 10-16-2017, 09:32 AM   #7
Bravo
That bypass sounds like a huge PITA.
I know that this feature is going to be standard on all combustion engines within the coming years, but for some reason it really bugs me (I'm probably making a bigger deal out of it than I should be).
Does the 5.0 on the F-150 do it as well? Cranking up a V8 after every stop seems like it would cause a ton of wear on the starter.
Old 10-16-2017, 09:50 AM   #8
Rickycardo
Rickycardo's Avatar
Drives: 2015 GT auto
Thanked: 397 Times in 251 Posts
Does then system read the car as stopped by engine speed or vehicle speed? Could you just keep your foot on the gas to increase the rpms to fool the system into thinking its not stopped? If that were the case maybe a tuner could turn it off permanently.
__________________
"Gru" - 15 GT/401A/Magnetic/Redline/3.55 Axle/20" Wheels
Mods, Sto-N-Sho LP bracket, Redline hood struts, Anchor Room brake light tint, MRT resonator delete, Diode Dynamics switchbacks and interior lighting, G2 painted calipers, Foose rear spoiler, GT/CS front splitter, Roush heat extractors, Verde Parallax 20x9, 20x10, Windows by Tint To U, Wrap by Xtreme Graphics
Rickycardo is offline   Reply With Quote
Old 10-16-2017, 09:51 AM   #9
ValidusTalon
Drives: 2017 GT Premium PP
Thanked: 1 Time in 1 Post
This is a feature on the daily driver I share with my wife (Mercedes GLK350) and to put it plainly we really dislike it. The implementation from MB is supposedly one of the best, and in truth it really doesn't interrupt us - starts fast and has not been an issue. It concerns me for wear and tear, and perhaps because I'm not so far removed from days when a car stopping at a light was a bad thing, makes me nervous ever time it does it.
Our routine is start the car, tap the button to turn that feature off, drive the car...I will re-enable it on longer highway trips however. I, for one, was happy to see it wasn't even an option on my '17 GT and would feel the same on an '18... this is not an eco focused vehicle
ValidusTalon is offline   Reply With Quote
Old 10-16-2017, 09:54 AM   #10
speedrx
Drives: Shelby GT500
Thanked: 25 Times in 21 Posts
We have it on one of our Mercedes, you can turn it off but not permanently, it reactivates each time you start. I am not a fan of the feature, not sure it really saves much and wear would seem excessive over time. Also, if you are stopped at a long red light, it restarts the car as it can't stay off too long running AC.
That hack to turn if off in the F150 is not great, I would like to see an option in the menu or via reflash
speedrx is offline   Reply With Quote
Old 10-16-2017, 10:01 AM   #11
Bravo
This reads like the F-150 has a physical button near the radio to turn it on/off - does the RS have the same button?
If Ford is controlling this with a physical switch, we might be able to see it in some of the 2018 interior photos.
Old 10-16-2017, 10:07 AM   #12
Bravo
Here it is on the F-150 (A with a circle)
Here it is on the RS:
Anyone seen this "A" button inside the 2018?
Old 10-16-2017, 10:10 AM   #13
K-Roll302
K-Roll302's Avatar
Drives: '17 Mustang EB/PP, '80 Porsche 931(924 Turbo)
Thanked: 259 Times in 115 Posts
I didn't see any buttons or switches with an "A" when I sat inside two 2018 Mustangs...
__________________
///Scout\\\ 2017 Mustang EB/Grabber Blue (RECAROS/PP/ESP)
(Ordered 7/19/16)/(Built 8/10/16)/(Delivered 8/17/16)
Mods:
Steeda Clutch Assist Spring / LMS 93 Stage 3 v7 Tune / LMS EvenFlo T-Stat / CP-E FMIC / UPR DVCC / GT PP Strut Tower Brace / Steeda Progressive Springs / Gibson Catback
(364hp/317whp)|(411tq/358wtq)
My YouTube Channel: https://www.youtube.com/channel/UCYm...EEp_HN_K58Y2KA
K-Roll302 is online now   Reply With Quote
Old 10-16-2017, 10:45 AM   #14
Bravo
FYI - the auto stop feature shows up in both the RS and F-150 manuals posted online, but it is not in the 2018 Mustang manual that Ford has posted.
It's only a matter of time before the Mustang has this feature, but the 2018 may have dodged a bullet.
Old 10-16-2017, 10:49 AM   #15
NoVaGT
NoVaGT's Avatar
Drives: 2016 GT Performance Pack
Thanked: 439 Times in 273 Posts
Is there ASS (auto stop/start) on any manual transmission cars? It would seem to me a manual car uses so little gas idling (not pushing to not stall against a torque convertor) that it would make very little difference.
__________________
2016 GT PP Triple Yellow
Bama Tuned, Plush & Luxurious Floor Mats
NoVaGT is offline   Reply With Quote
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Gt 350 stop/start button welsh treg Member Classifieds / Marketplace 3 08-09-2017 12:34 PM
Push start/stop prem Mustang S550 General Forums 49 11-23-2016 01:43 PM
Engine start/stop JimmyTwoTimes Mustang S550 General Forums 38 04-20-2016 07:26 PM
Ford Stop/Start system Tamadrummer88 General Automotive Topics (non 6th Gen Mustang) 2 03-29-2015 07:49 PM
Automatic Engine Start/Stop Mustang Convert I4 2.3L EcoBoost Engine / Mods: Bolt-ons, Exhaust, Tuning 6 11-12-2014 05:30 PM
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging v3.2.4 (Lite) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.Navbar with Avatar by Motorradforum
Garage vBulletin Plugins by Drive Thru Online, Inc.
