CJ Pony Parts
- Dec 21, 2015
- Harrisburg, PA
- Website
- www.cjponyparts.com
- A large variety of Mustangs across all generations
Steeda G-Trac Ultralite K-Member Brace for all 2015, 2016 and 2017 Mustangs.
If you love your new 2015-2017 Mustang but worry about movement during track events or just while you're cruising down the road, than CJ Pony Parts has the perfect solution for you! Steeda's G-Trac Ultralite K-Member Brace (555-5533) will stiffen your pony's front end and provide additional vehicle response--order yours today!
[ame="[MEDIA=youtube]Hf3TBDSprAQ[/MEDIA]"]
Steeda Ultralite G-Trac Brace Features and Benefits:
- Improves overall chassis stiffness and suspension compliance
- Ultralite edition weighs in at 5.5 lbs.
- Improves Mustang response and predictability on the street or track
- Installs in minutes without special tools
- Compatible with OE factory and aftermarket components
- Proudly made in the U.S.A.
The revolutionary G-Trac bar was developed to stiffen the K-member and maintain proper suspension geometry in max-G cornering. The ultralite G-trac brace is attached as close to the control arm bushings as possible so the load path is more direct and you get much more effective stiffening so the suspension geometry doesn't change during high cornering/chassis loads. Steeda has designed this ultralite brace to fit every model of 2015-2017 Mustang, so no matter your pony's make or model your S550 will have the competitive advantage you need on the street or on the track!
Order this Steeda 555-5533 G-Trac Ultralite K-Member Brace for your 2015, 2016 or 2017 Mustang today from CJ Pony Parts!
