CJ Pony Parts
- Dec 21, 2015
- Harrisburg, PA
- Website
- www.cjponyparts.com
- A large variety of Mustangs across all generations
Steeda 35 Lb/In Clutch Spring Assist and Spring Perch Kit for 2015, 2016 and 2017 Mustangs with a Manual Transmission.
If you're considering removing your new 2015-2017 Mustang's clutch assist spring because you hate the feel of it, wait just a minute! Removing it can lead to a damaged slave cylinder, so why not just replace it with a premium-quality, heavy-duty spring that will make your clutch more responsive instead? CJ Pony Parts has exactly what you need in Steeda's 35 Lb/In Clutch Spring Assist and Spring Perch Kit (555-7027)--order yours today!
Steeda Clutch Upgrade Kit Includes:
- Steeda Mustang Clutch Spring Assist 35lb/in
- Steeda Mustang Clutch Assist Spring Perch
[ame="[MEDIA=youtube]UnhbNu1Qne8[/MEDIA]"]
If you're already sick and tired of the way the clutch feels vague and disconnected in your new Mustang, than stop living with that factory 185 lb/in clutch assist spring and upgrade to Steeda's 35 lb/in spring instead! Your factory clutch assist spring combined with the motion of the clutch pedal can cause a non-linear and sometimes confusing pedal feel. Many daily drivers found that simply removing the clutch assist spring altogether gave a better, more controlled feel. However, by removing this spring and not properly replacing it with another, you'll notice a huge increase in chatter and NVH from your clutch pedal, making your daily commute loud. Don't forget, without the spring your clutch won't return to stock position, meaning your slave cylinder may begin leaking due to constant pressure on its seals. Don't ruin your new pony and instead replace that terrible factory clutch spring with Steeda's premium-quality spring and heavy-duty spring perches!
Clutch Spring and Perch Kit Features and Benefits:
- Easy direct-fit upgraded parts install with basic tools in under an hour
- Steeda's 35 lb/in spring constructed from premium piano wire consistent spring rate and minimal sag
- Clutch will immediately feel more linear and responsive when engaged
- No risk of damaged slave cylinder or cracked seals
- Durable construction and heavy-duty pieces means these parts will last for years without wearing-out
Steeda's premium-quality clutch assist spring will work in tandem with their new heavy-duty spring perch to ensure that your new Mustang's clutch is super responsive and non-linear. These pieces are direct-fit upgrades to your OE factory spring and perch and they'll ensure that your slave cylinder isn't damaged due to increased seal pressure. Don't allow a simple thing like a clutch spring to make your daily commute feel uncomfortable! This upgrade kit will allow you to feel everything in your clutch and can make driving your new pony fun again.
Order this upgraded Steeda 35 Lb/In Clutch Spring Assist and Spring Perch Kit 555-7027 for your new 2015, 2016 or 2017 Mustang with a Manual Transmission today from CJ Pony Parts!
