Yes, I have the BK050 and BK048 bushings. Is this hardware an improvement??Are you referring to BK050 Diff Bushings?
You are far from alone, hence me making this thread.The BK050 is awesome. I know I will never shear a diff bolt again so it gives me a lot of confidence to give the car hell. There's little vibration; mostly noise. Well worth the peace of mind. Besides, dropping the cradle once for a sheared diff bolt was bad enough.
Thanks,Either direction places the shear on the shank.
It really does not matter.
I am going to run mine in from the gas tank towards the rear of the car. My reason is because, I don't want to remove my halfshafts. ;)
No, you would not use the lock washers. Only the hardware as I pictured above on the 9/16" bolt.
