Carfanatic
Anyone know if the performance pack option includes the ford racing knuckle to toe link bearing?
All GTs and the EB PP comes with the toe link with the bearing on the inner joint (identical to the one in the track handling pack). V6 and non-PP EB cars have a bushing there.Found this thread in pursuit of the same answer.
Wish ford provided what exactly comes with pp. Here is cjpp stating in the q&a that we do have the knuckle/toe bearing
www.cjponyparts.com/ford-racing-track-handling-pack-assembled-fastback-ecoboost-gt-2015-2017/p/MFR3AM8/e/toe b
I'll try my vin with ford parts microfiche, maybe that will help.
That link won't work, edited 2x and still no.That link didn't work for me but they must be referring to the other other end of the toe link. That is on the PP but the problem is that it connects to the hub through a piece of Crap rubber bushing with voids all over it. You will come to hate it during removal but I consider it a necessary mod. You can change it with the FRPP bearings or even better as Kelly stated get the BMR kit and then press out the bearing in the little black arm and then you will have two Free bearings to put in the knuckle.
Experiencing that right now. Strike 2 on changing mine out today. Ball joint press didnt work, homemade press didnt work, mine are stuck. Gonna have to pull the spindle and press them out. Anybody have a part number for the axle end nut at the spindle so I can replace them when I pull it?My advice is to take the hub off (it is just a few bolts and very easy) and use a press when changing the bearings. It is not very fun fighting with it under the car.
