earlSpilner
ok glad I was not the only one.Great job! I had the same look on my face when the parts guy handed me the duct. :lol:
Us Canucks have to home brew as much of this stuff as possible because buying a kit (if one existed) would be painfully expensive with the US exchange rate and Fedx charging stupid money for customs. Hence the Canadian tire builds. I'm a socialist at heart (guess which colour I vote ) so I bought as much of this stuff as possible from my local none-chain parts store (JB's Power center https://www.jbspowercentre.com/ ) They ship free in Canada FYI. I believe in keeping the cash local as much as practical.Thx Earl, nice to see a Canuck tackle this job, if i ever decide to add the coolers, i know all i'll have to do is drive a few hours and bring a case of Molson. :cheers:
The pump was actually ordered from Racer Parts Wholesale out of IN and the B&M supercooler line, at least in Canada, seems to be carried by every parts store around so I would expect you could find the same one locally.This is a great write up and effort for the base and tech Shelby owners. Greatly apppreciated by all for sure. Glad to hear that the fruits of your labor paid off.
Is the pump and cooler something that can be sourced in the US as well?
I am in Virginia, I wonder how far it is to your place....��������
OMG, you're way out west.The pump was actually ordered from Racer Parts Wholesale out of IN and the B&M supercooler line, at least in Canada, seems to be carried by every parts store around so I would expect you could find the same one locally.
As for how far away I am from you google says 3782km (2350miles)
The FP kit is made to be installed with the transmission swap.Great thread! Has anyone installed the actual FP kit on a tech or base transmission? I know a few, like the OP and SVTDSM have gone with other aftermarket brands and Hack and 50Deep have done the total trans swap. Haven't seen any FP swaps though. Leaning hard that direction to ease shipping woes.
Yeah, I know I'll need a pump and brake vent, but I think everything else comes with it. After 15* laps of babying it around the N'ring Monday, I'm ready for a cooler!The FP kit is made to be installed with the transmission swap.
If you use it you will still need additional hardware like lines because the ones in the kit will not work with an external pump.
The lines that come with it wont work either.Yeah, I know I'll need a pump and brake vent, but I think everything else comes with it. After 15* laps of babying it around the N'ring Monday, I'm ready for a cooler!
As Lemers said, unfortunately the kit has many parts you don't need if not swapping the transmission, such as hard lines, etc. and it doesn't have the electric external pump, so still need to get that separate anyway. Best to individually source most parts. I plan to buy the duct on it's own, everything else will be separate. I suspect all said and done I will spend less than the FP kit and I will have the pump too. In no particular rush as no plans to track car anytime soon and my temps are fine on the street, but appreciate everyone posting how they did it as it will make my work easier.Yeah, I know I'll need a pump and brake vent, but I think everything else comes with it. After 15* laps of babying it around the N'ring Monday, I'm ready for a cooler!
Nice color by the wayLast part: Rad mounting and the hoses
image1$$ (00B) by bmalkins2, on Flickr
^ so next up you are going to need to make a bracket for the Rad. I would start with the upper bracket. Just like the lower bracket it will need a bend in it to match the angle of the rad.
When mocking this up I aimed to get the rad as close as possible to the windshield washer reservoir. This was for two reasons 1) it meant shorter more stable brackets and 2) I needed the output of the rad to miss the input of the pump (see pictures)
image5$$ (003) by bmalkins2, on Flickr
^installed picture of the upper rad mount
image3$$ (003) by bmalkins2, on Flickr
The lower rand bracket goes the length of the bottom of the rad and actually comes in just above the main lower bracket. The original intention was for this to be level with the main bracket but with the pump it wouldn't work. As a result the extra vertical tab was needed
Next couple of picture show the fully complete bracket out of the car. I would expect yours would look something like this.
image2$$ (004) by bmalkins2, on Flickr
image4$$ (003) by bmalkins2, on Flickr
^ IMPORTANT note how in this picture the pump is NOT LEVEL with the ground. In order to have output of the pump end up in that indent space in the bumper I needed to angle the pump up about 10ish degrees from the horizontal plane of the car.
This picture also shows why the rad has to be higher than the main bracket or else it would block the input of the pump.
image8$$ by bmalkins2, on Flickr
^Next up plumbing. Note that it is way easier to install the output line on the pump (pump to transmission fill) with the rad not installed.
Three hoses need to be made:
1) Pump output to transmission fill. This is the longest hose and should be made first as installing this hose BEFORE installing the rad will make you life way easier. Like all the hoses add 90 degree fittings on each end. If you haven't already install the 3/8 to 8AN fittings on the pump using some sealant on the threads and the 1/2 to 8AN fittings on the transmission and rad.
2)next do the trans drain to rad hose.
3)lastly make the super short (like 5") rad to pump hose
image6$$ (002) by bmalkins2, on Flickr
^ giving an idea just how close the rad and pump hoses are to each other
image7$$ by bmalkins2, on Flickr
image9$$ by bmalkins2, on Flickr
^ Next up wire up the pump. I wired the pump using the stock grounding location just to the right of the Windshield washer reservoir. For the positive I tapped the pos input to the fuse box. From there I ran it through a 10amp fuse and a switch. In the future I plan to replace this with a relay and a in car mounted switch. But I was running out of time before my track day. The result? The car ran hard in 25C outside temp. No sign of limp mode.
