BMR Tech Tip: Check those axle-to-spindle retaining nuts!
Status
Not open for further replies.
chadhtx40
Frisco
2015 Ecoboost Premium PP Magnetic Metalli
[MENTION=18561]bandit67[/MENTION] CCPZ-3B477-F is the hub nut part number
Thanks to this thread the popping and clicking at low speeds is resolved.
At 120lbs I got a good 2 full turns, at 150lbs I got another 1.5 turns. My issue was popping at low speed take off, and a clicking noise on low speed deceleration. Noticeable mainly when in gear. MT tranny. I thought it might be the metal diff lock out, the ring and pinion backlash, or even my upgraded vertical links. Turns out the nuts just were not tight enough.
Gurjit
B.C. Canada
2016 GT Premium performance pack
Dealer fixed this issue for me on 03-23-2017 by replacing both half shaft axle nuts
the noise is back now, as I predicted on post #2
Well of course it is, there's nothing to keep them from backing out.
IF the issue is the new axle nuts are backing off, even after being torqued to 150ft lbs, here's a thought...
When the E36 M3 debuted back in the mid 90's, a problem that became widely known while road racing or auto crossing was the oil pump nut would vibrate loose and cause engine damage. After multiple failures were being documented from track events and from daily drivers, it was found that over time (without knowing when), the nut would eventually work its way off the pump shaft resulting in engine damage.
The fix:
Folks who found out about the issue started doing preventive maintenance on all E36 M3's by removing the oil pump nut, carefully drilling through it, reinstalling the nut onto the shaft and then would safety wire tie the nut so that it could not vibrate loose OR back off the shaft again. Today, these are now mass produced and folks can purchase pre-drilled oil pump nuts.
Has anyone attempted to drill through the S550 rear axle nut and try safety wire tying it?
I'm including a pic (courtesy of ECS Tuning) to show a provisioned E36 M3 oil pump nut for reference so it can be seen how the nut was drilled and also a pic showing how the safety wire tie off was used in the BMW M3 application.
Granted we're talking S550's and the axle nut is different from an oil pump nut, but safety wire tying might be possible.
natepcbfl
New Hope, AL
Nathan
2015 Mustang Premium GTpp 50th AP ---- 1989 Mustang GT 25th Anniversary
So car is at the dealership, getting only the driver hub and half shaft replaced. Not sure how I feel about them only doing one side. They said it was the splines that are damaged from when the nut loosened up that is causing the noise. Guess we will see how long it lasts. I will try to take some pictures of the old parts when I pick it up.
TexasRebel
Gearshifter
between the mustard and the mayo
2016 YZ GTPP - PP2
The fix:
Just a note! That is a left-hand thread. If you go to safety wire anything always make sure your safety wire pulls in the correct direction.
natepcbfl
New Hope, AL
Nathan
Its mostly just dirt and some surface rust, looks worse in a picture. When I looked at the parts in person they really dont "look bad". But there is that one funky spot on the splines. I am wondering if it was the bearing myself. Maybe when it loosens up there is not enough load on the bearing it causing it to bind? Hell I don't know, its purely speculation.
whatsup62
Jupiter
Am I mistaken or are all of these on PP cars?
natepcbfl
New Hope, AL
Nathan
bandit67
Mustang Addict
Lake Hartwell, SC
2015 GT, 2007 SPJ 302, 2019 Ranger
Could just be that a larger percentage of PP owners work on, tinker with, or modify their cars, and are therefore noticing/checking for more issues?
natepcbfl
New Hope, AL
Nathan
Not for this issue, it's loud and noticeable.
Status
