firestarter2
How long would you say all 4 took
Thanks for the heads up!Just talked to Mike. He is expecting them anytime now
So while we were installing a buddy's springs yesterday, I noticed this and was a bit confused about it.Rear left spring comparision
Very interesting question. When you think about how the spring will move, if the wire is the same diameter everywhere, the tight coils effectively have a lower spring rate. So there will be more compression in the area of the spring that has the tight coils. Off the top of my head I would think it would be better to have the tight coils on the bottom, because the amount of mass moving with the tire/wheel/suspension is reduced. However, it's going to be reduced such an extremely small amount because the coil spring is a small percentage of the total unsprung weight that the difference is probably imperceptible.So while we were installing a buddy's springs yesterday, I noticed this and was a bit confused about it.
Any thought on why they would switch the tight coils from the bottom on stock to the top on lowering springs on these?
I've been doing a bit of digging. I think the difference is - the stock springs are linear, these lowering springs (in the rear) are Dual Rate. I think. That makes more sense to me in the big scheme of MagRide tuning and the different shock modes.Very interesting question. When you think about how the spring will move, if the wire is the same diameter everywhere, the tight coils effectively have a lower spring rate. So there will be more compression in the area of the spring that has the tight coils. Off the top of my head I would think it would be better to have the tight coils on the bottom, because the amount of mass moving with the tire/wheel/suspension is reduced. However, it's going to be reduced such an extremely small amount because the coil spring is a small percentage of the total unsprung weight that the difference is probably imperceptible.
After considering a little more, I think they probably they changed it so that it's easy to tell the difference between the stock springs and these aftermarket ones.
