Correct your speedometer error - no flash or tune required
Spart
Spart
Iowa
17 GT350
Your entry looks good to me, but the way to know for sure is to check the speedometer against GPS!
No idea on the DTC's. Doesn't look like anything serious but I'm no expert. What you said about the tail lights makes some sense, most newer cars are able to detect when a light is out.
tedj101
Wilmington, DE
Ted
2018 Shelby 350GT Steeda springs, sways, camber plates, toe links etc: 14 BMW 328d
Many, many thanks for this information! This is a great help. It will make changing tire sizes a non-event...
<TED>
earlingy
Rocket City, AL
2016 Mustang GT Premium Performance Package
Can you use this method to change the front tire size for ABS and traction control?
Spart
Spart
Iowa
17 GT350
No, this is for the speedometer and odometer. What issue are you having?
earlingy
Rocket City, AL
Well, ABS and traction control look at your tire speeds. If you were to change sizes, those systems are getting an incorrect reading on current tire speeds. I want to change sizes but not mess with ABS or traction control. Seems like it'd matter a little more if you changed front and rears different amounts, say, from a regular GT to PP wheels/tires.
Spart
Spart
Iowa
17 GT350
I'd have to agree on changing the front and rear different amounts, but I haven't heard of anyone having problems? Not that I've gone looking...
earlingy
Rocket City, AL
I'd kinda like to go to a square setup on my GT PP. I also haven't heard of anyone having issues but I'm a paranoid/OCD engineer so...
Spart
Spart
Iowa
17 GT350
Looking at some as-builts I have on hand, my GT PP differs on several lines in the ABS module (760) from a GT without a PP.
I can't make heads or tails of the differences though.
solodogg
Orlando
2015 Mustang Ecoboost
can we make this sticky? This could be extremely helpful for those running non-oem tire sizes.
Ingot2015
CT
Ron
2015 gt
would this work for rear gear swaps?
zuki_dan
North Carolina
15 Mustang GT Premium M6 TY
Should be a different memory block in the BCM for gear swaps. I don't know that anyone has confirmed it working yet but it should work. Check out the AS built thread in the DIY forum sticky.
As Built thread
law242
Arizona
2015 Mustang Ecoboost Premium
shouldnt the dealer be able to fix this? i mean cummon we spent good money on these cars.
Spart
Spart
Iowa
17 GT350
Should they? Of course, but nonetheless this thread must exist. Don't complain here, complain to Ford.
RubyRed15
Ok, so it's blue.
CO
Ecoboost Premium PP
So we've finally figured out how to correct speedometer error (if your car is just off from the factory or you've changed tire sizes.)
Any idea if a similar method would work to correct the difference between the main speedo and the set speed displayed for cruise control?
