Looks like fun! Do you have a pic of your slip? Why such a short burn out? My hoosier's I light up for about 4 seconds, that's about when I can feel them start to push me through the brake. I'm hoping to get down to the track in a week or 2 depending on weather. I'm really looking forward to seeing what kind of 60ft I can get on my new suspension set-up. Stock suspension I pulled a 1.68 60ft so if I don't at least top that I'll be very disappointed. I try not to get my expectations up too high because I know it can take some time to get a new set-up figured out.Well, I did what you told me to do lol! This was me tonight. 6K rpm dump with 12psi in them. *Bonus footage of @Evil 5.0 doing a burnout at the end
The blueprint is already out there. Anyone with any skill at all should be able to reproduce the 1.5 results.I'm liking the results on these so far. I'll hopefully be hitting the track again Wednesday with the hoosiers and I'll decide from there. If I can cut a 1.50 60ft, I'll probably stick with them unless it's race that requires "street" tires.
Picked up a pair of the ET Street R Bias ply's recently. 28x11.5-17's mounted on racestars.
Gave them a handful of good run's at MIR last week and they were dead hooking! Never ran the Hoosier's or any other bias ply/slick type tire for that matter so the only comparison I have is against the MT ET Street S/S's I ran before.
Car is a 2015 Whippled GT M6 with 3.31's. Still on the stock MT82, stock clutch, and stock driveshaft. I do have the DSS 800hp half shafts and full BMR rear suspension. Car put down 680/500 on the dyno. To paranoid about breaking the stock drive-train so I was slipping out the clutch quickly on every launch. I did not try a clutch dump although I am pretty confident the tires would have hooked just fine if I did (will have to wait until I get the Magnum XL in ).
First launch at around 3,500 slipping the clutch out quickly. Dead hook but bogged a bit. Never launched on a tire this sticky and it was freaking awesome. Scared the shit out of my how hard I got thrown back in the seat and missed 3rd with the adrenaline pumping. Didn't save the slip but think it was a 1.7 60'
Progressivly stepped up the launches and consistently cut 1.5x 60's the rest of the day. My final and best run I launched at just under 5k, slipping the clutch quickly and got my best 1.557 60'. No doubt the tires would have hooked just fine with a harder launch but I am a pansy.
Long story short, I loved these tires!
You should be able to drop that sixty. Were you spinning or bogging? If spinning you need more heat in the tires if you were at 14 psi, unless that was 14 psi cold. If bogging let her rip at 6k! It is normal to drop a little mph on a bias vs radial. When you get it figured out don't worry your next time at the track that recipe won't work.:headbonk: I very seldom get my best pass on my first run and I always start at what worked best last time.
15 premium ppgt
Sw lt 1 7/8
Corsa cb
Pmas intake
Lund 93 tune
Bmr-
Toe rods
Vert links
Cb005
Bk005
Gforce halfshafts
Bmr front springs and eibach pro rears
Viking crusader 5c 9r
Mgw xspec
McLeod clutch
Whiteline tranny bushing insert
Weld rts-71 on mt et street r bias
MandH bias front tires 28/4.5/18
First time tracking the car and first time on bias ply.
I was leaving between 5000-5500. Tires at 14psi. I noticed that my mph is lower than most at 90 vs 92 that I see the most. Was going to change the rear springs back to the bmr springs and change the Vikings settings to a little more aggressive. Opinions on my times and any advice please.
