16TT
- Apr 11, 2017
- Tarpon Springs,Fl
- 2016 Mustang GT Premium/Auto, Oxford/Redline
Sai was running it on the dyno so I know it was done correctly. I'm running NT05Rs (305/19, 18 lbs.) and I discovered on my last couple of passes that they worked much better with a long, smoky burnout, which I wasn't doing earlier. I ran out of time to try to increase the rate but I'd be surprised if I could increase the rate into the 30s (wish/hope I can though). I know a dedicated track wheel/tire setup would work much better but I want to see how fast I can get it to run on the drag radials I use on the street and drive 60 miles to the track on. Thanks for the tips-152 is crazy fast-these engines are amazing!Make sure you open Rate to 50/Max when on the dyno, thats the only way to get peak #'s. I've been able to open up 18-20psi at 35 & 40 Rate on some of my best pass's (9.3@152) but now I have a dedicated set of Welds and MT R's, going to open Rate to 45-50 next time out. Good luck, let me know if I can help!
