solodogg
found another feature over on the F-150 forums that I can confirm works on the automatic Mustang called Secure Idle.
Basically, this allows you to exit the car with the key, leave the car running, and keep the vehicle from engaging any gear (shift interlock will not allow the shifter to move). Perfect for those that want to run in the gas station, but don't want to shut the car off while doing so. This also prevents the vehicle from allowing a restart after the key has been removed (stock allows you to restart the car within 30 seconds of shutting it down even if the key has been removed from the vehicle).
726-42-01 x0xx xxxx xxxx (Secure Idle disabled)
726-42-01 x1xx xxxx xxxx (Secure Idle enabled)
